Biggest tire without spacers? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Tires
Tires Tires
Old 11-04-2006, 05:34 PM
EvilTwin v2 EvilTwin v2 is offline
2004 Chevy TrailBlazer LT EXT
Indigo Blue Metallic 5.3L V8 4X4
I've searched & searched & read & read & haven't found an exact answer. What is the biggest tire that will fit on stock 17" wheels on my TB EXT without wheel spacers.
Old 11-05-2006, 01:30 AM
guano2's Avatar
guano2 guano2 is offline
2002 Chevy TrailBlazer LTZ
med grn prl & lt. pewter 4.2L I6 4X4
I,m curio about this myself as TB needs new treads.
Old 11-05-2006, 01:39 PM
geneelder's Avatar
geneelder geneelder is offline
2005 Chevy TrailBlazer LS
255/70/17 is the largest some people are currently running without wheel spacers.
2005 Trailblazer LS 4x4
Old 11-05-2006, 07:16 PM
idreama300's Avatar
idreama300 idreama300 is offline
2006 Chevy TrailBlazer SS
Red Jewel Tintcoat 6.0L LS2 V8 2WD
I am looking at getting 22's and want to get the largest size tire I can with stock suspension. i have read in past threads that people have used various sizes like 265/65/16 (30.7"), 255/70/17 (31.1"), and 255/75/16 (31.1"). Is it the width of the tires that is limited or is it the height? I have also seen people use tires such as 285/35/22 (29.9) which is wider than all of these but not as tall. So based on this could a 285/40/22 (31.0") work?
2005 Envoy SLT, PCM4Less Tuned, K&N FIPK, Magnaflow Dual Exhaust, 5% tint, Street Scene grilles
Old 11-05-2006, 07:24 PM
Trailblazin's Avatar
Trailblazin Trailblazin is offline
2007 GMC Yukon Denali
Black Other AWD
it should be able to if the rims u get have enough offset on them... I was running 275/45/20s with no problems... there was ALOT room for more rubber, but I didn't wanna lose too much performance...
'07 GMC Yukon Denali
220/234 .570/.588, ARH 1 3/4" with 3" ORY, PRC Doubles, LC1, TVS1900 w/ 2.8 pulley
Old 11-05-2006, 07:53 PM
idreama300's Avatar
Most of the wheels I have been looking at are something like 22x9.5 with a +15 or +18 offset, but I think that I have also looked at some that were +30 offset if I'm not mistaken. I'm not really sure how all that works though.
Old 11-05-2006, 08:29 PM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
In stock form, you really dont have but maybe a half an inch in width and height max to play with before you will rub the upper balljoints on the font end. Good rule of thumb, check this handy site: http://www.miata.net/garage/tirecalc.html
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 11-05-2006, 10:27 PM
Air Defender Air Defender is offline
265/65/27 Will Fit on Stock Wheels
I have Bridgestone Dueler A/T Revos in 265/65/17 on my stock 03' TB Ext 4x4. They fit with no interference issues.
Old 11-05-2006, 10:39 PM
idreama300's Avatar
Defender, do you think that there would be room for another 20mm of width and 0.3" of height? I believe that both of those numbers would only be half also because only half of the width is on the inside and half of the height is on the top of the axle, is that right?
Old 11-06-2006, 07:54 AM
Thanks. That's exactly what I was looking for.
How do you like those tires? Any pictures of them on it? You wouldn't happen to have a picture of the clearance at the upper balljoint would you?
Thanks again!
Similar Threads
Biggest Tire for Stock height zac2005ss Tires 0 05-16-2008 02:21 PM
Biggest tire for 18's rmsg0040 Tires 0 05-03-2008 06:26 PM
What's the biggest 18" tire that can fit on an Envoy? bigbodyla Tires 3 02-06-2008 12:30 PM
Biggest tire w/ 20 inch rim itchyfishnv Rims 11 01-07-2007 04:25 PM
Biggest tire that will fit on a 20" rim on a stock TB? nrk81 Tires 1 10-09-2005 10:26 PM
