2002 Envoy ECAS failure fix - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 11-08-2006, 02:52 AM
anav3333 anav3333 is offline
2002 GMC Envoy SLE
Lightbulb 2002 Envoy ECAS failure fix
Just wanted to post this so anyone else with this problem doesn't go thru the headache I did. My 2002 Envoy with ECAS went on the fritz. Instead of spending a lot of money (1000's) to have the dealership fix it I went to autozone and purchased an old airshock repair kit ( they were great in the 70's) they had in the back for $14.00. Removed the compressor unit ( 2 screws ) and disconnected the air lines from it. I then cut off the brass fittings from the end of the lines and simply connected it to the t-bar connector that came in the kit with supplied connectors, applied about 60lbs of air (adjust to your desired height) and cleaned up. It took about 30 mins. Make sure you remove the fuse for the ECAS located under the hood on drivers side fuse box ( fuse 1 ). Sounds crazy but it works great and only cost $14.00.
Old 11-08-2006, 10:49 AM
Envoy Fan's Avatar
Envoy Fan Envoy Fan is offline
TrailVoy Guru
2005 GMC Envoy Denali
Summit White 5.3L V8 4X4
Great fix. Any pics?
BILL
Old 11-08-2006, 06:11 PM
2002 GMC Envoy SLE
more to come
This fix has worked perfectly for the past few weeks. I am going to make it even simpler. When disconnecting the lines from the compressor , I should had just linked the existing air bag lines to the tire inflater line ( with brass compression fittings) so pressurizing the air bags can be done from the existing valve in the back cargo area. When I complete this I will post pics with exact specs on what type fittings and line I used to complete> This should make it even easier to do because the fittings can be obtained about anywhere and last longer.
Old 11-09-2006, 08:18 AM
xceebeex xceebeex is offline
2002 Olds Bravada
Indigo Blue Metallic 4.2L I6 AWD
Isn't there a recall out there on the ECAS? At least there is for my 02 Bravada. I am not sure what kind of failure you had or what the recall is supposed to fix, but just wanted to see I guess.
Old 11-09-2006, 05:36 PM
2002 GMC Envoy SLE
I had the recall completed on my Envoy and it had to do with stalling the vehicle, didn't cover compressor or sensors. I worked in a multiplex dealership as a used car manager so I had all recalls and any warranty work completed on the vehicle before it went out of warranty. Thanks anyway.
Similar Threads
Envoy 4.2 Vortec 2002. Aftermarket CAT= Check engine light phatz OEM Issues 1 05-18-2008 11:08 AM
Idea to fix 2002 Mirror issues fife2001 General 21 10-31-2007 04:09 PM
2002 Envoy SLE Stewy33 Introductions 9 04-16-2006 03:45 PM
DDX-8017 Installed (2002 Envoy) JLous_EnVy Audio and Electronics 7 03-02-2006 06:29 PM
New Recall on 2002 & 2003 Envoy XL's deemota TrailBlazer / Envoy Chat 1 10-28-2005 10:49 PM
