Help,check engine w/P0601 code - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-13-2006, 12:37 PM
TheWETZ's Avatar
TheWETZ TheWETZ is offline
2002 Chevy TrailBlazer LTZ
Dark blue and tan 4.2L I6 4X4
My TB has thrown a P0601 "Check sum error" code. From what I gather on this problem it is linked with the PCM. The PCM (Power Control Module) is part of the emissions control, therefore should be covered under the 80K miles or 7 years which I fall under both.
The dealer is telling me it is a problem with the PTM (Powertrain Module), and they want $800 to repair this .
So WTF is the difference between these two components?
Are they the same part and the dealer is trying to make me pay for it by calling it a different part.
I need help and fast. My TB is still at the dealer and they are waiting for my call as to what will happen with it.
Thanks.
Old 11-13-2006, 01:02 PM
rrmccabe rrmccabe is offline
2006 Chevy TrailBlazer SS
Silverstone Metallic 6.0L LS2 V8 AWD
I am guessing they are talking about the TCM module.
You can see it here http://www.***********/rich/ecmtcm.html
That sounds like HUGE money if thats the case. I though the part was less than $200 and you dont even need tools to replace it.
I am assuming this is what they are talking about. If so, no way on $800.
2006 AWD SS - Vector Tuned
Old 11-13-2006, 01:08 PM
TheWETZ's Avatar
I'm not sure about the TCM, but then again I am not sure if the "Powertrain module" is the same as the "Power Control Module".
I just called other dealers and from what I gather they are one in the same.
So if that is the case, would I be able to buy a Tune from "PCM for less" or "Wait for me", ect... and have that solve my problem?
Old 11-13-2006, 01:11 PM
No, I dont think so. Because that tune does not touch the other module.
And you have not sayd what truck you have? Year, etc.
EDIT: I just found you in another thread. And see you have an 02. I dont know about that. Think I remember reading it was all in one module back then so maybe its different.
Sounds like your problem might be in that from what I read on Google searches. How much are they saying the parts cost?
Old 11-13-2006, 02:14 PM
TheWETZ's Avatar
My TB is a 2002 LTZ with 40,000 miles on it.
The repair will be around $800 (includes PCM, reprogram and labor).
I have checked other dealers and they are about the same price for this thing.
But I am still having a hard time understanding why I am having this problem. The vehicle sees around 10,000 miles per year and why the software is not covered under some type of warranty.
I understand how the software works (I used to program with C++/MatLabs). This is something that is not touched, except by the programer of the software. So I would link this problem back to the time it was programed.
But at this point I really have no choice but to pay for the repair , they I might sell it and be done with it.
I have started to loose my faith in GMC/Chevy .
Old 11-13-2006, 02:28 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
If it's a 2002 i6 then the PCM (Powertrain Control Module) and "powertrain module" are one in the same. The PCM is covered in the Federal Emissions warranty section in the owner's manual.
Otherwise you could contact one of the PCM tune sellers and buy a replacement PCM from them. You provide your VIN and get a replacement programmed stock or a performance tune. I think W4Me and PCMforless can do that for about $150-160 total.
Old 11-13-2006, 02:31 PM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
Summit White 4.2L I6 4X4
Hmmm, the '02 I6 uses a single PCM (Powertrain Control Module) for engine & trannsmission control. If its bad, I would expect it to be covered under the emissions warranty....that is one of the items listed as being covered. I'd try calling GM directly and inquire as to just why the dealer would be denying covering the PCM under the Federal Emissions warranty.....might just be your dealer just doesn't know that it should be covered. (Setting up a claim under the 7/80 emissions warranty can some times be a real PITA and the dealer might just be trying to avoid it, but trying to have you foot the bill).
Old 11-13-2006, 02:36 PM
Blueblazed's Avatar
Blueblazed Blueblazed is offline
2005 Chevy TrailBlazer LS EXT
Superior Blue Metallic 4.2L I6 2WD
Before I forked out 8 big bills I'd get a second opinion. I agree with Ylab - I'd make a lot of phone calls and fight them on this.
Old 11-13-2006, 02:40 PM
TheWETZ's Avatar
Where can I find the info on the PCM and how is it linked to the emissions?
I have used the emissions once on my VW for the cat, and I would love to use it for the PCM and save me some money.
So how can I make this work?
Do you have the direct number for GM?
How is the PCM linked to the emissions?
I have asked the dealer about it already and they either played dumb or they don't know about that type of warranty.
Old 11-13-2006, 03:08 PM
Blueblazed's Avatar
Here is one for starters:
http://www.epa.gov/otaq/consumer/warr95fs.txt
" There are three specified major emission control components,
covered for the first 8 years or 80,000 miles of vehicle use on 1995
and newer vehicles:
* Catalytic converters.
* The electronic emissions control unit or computer (ECU).
* The onboard emissions diagnostic device or computer (OBD).
The electronic emissions control unit or computer monitors
certain powertrain functions and controls various operating parameters
to help the vehicle run efficiently and with the lowest possible
emissions. Ignition, transmission function, air injection, exhaust
gas recirculation (EGR), engine operating temperature and fuel system
parameters are some of the systems monitored and/or controlled by the
electronic emissions control unit.
Similar Threads
Build Sheet lucaswhunter General 29 05-27-2012 01:42 PM
Secondary Air Intake Engine Code nathnn99 Air Induction 15 06-14-2011 01:24 PM
Reduced Engine Power due to a P0128 code? onip28 OEM Issues 2 12-09-2007 03:02 AM
Gen IV 5.3 LH6 Info... Windy City Engine Tunes/Mods 7 08-08-2006 10:41 AM
05 TB DOD status? muddy tires 02-09 Vortec 4.2L I-6 Engine and Drivetrain 19 07-28-2006 10:00 PM
