Intermittent cruise control issue. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 11-15-2006, 09:08 AM
chester_9's Avatar
chester_9 chester_9 is offline
2002 Chevy TrailBlazer LTZ
I have a 2002 Trailblazer LTZ that I purchased recently. I love the truck and everything seems to work as advertised - or so I thought. The cruise control worked fine for the short trips I made here and there. I recently made an 8.5 hour trip to VA. The cruise was used for most of the trip. Toward the end, the cruise just turned off on its own and would not engage again. After fiddling around it finally came back on for about 1/2 hour then went off on its own again.
Here is the problem - it seems that the cruise is intermittent now. Sometimes it engages, sometimes it won't. Sometimes its fine for a few hours, sometimes it quits in a few minutes. Sometimes it will engage again right away, sometimes it won't engage till the truck sits for a few.
Has anyone else experienced this problem?? Any suggestions as to where to start troubleshooting the problem??
Any help would be greatly appreciated.
TIA!
Rob D.
Old 11-15-2006, 09:53 AM
85vette's Avatar
85vette 85vette is offline
TrailVoy Guru
2004 Cadillac TrailBlazer LT
Majestic Red/Sandstone 4.2L I6 2WD
My guess is the switch.
Old 11-15-2006, 11:45 AM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
several years ago- in my 03-
we drove thru the desert- temps were close to freezing-
I used cruise most of the way- there came a point, where I got off to get gas, when we got back on highway- Cruise WOULD NOT set.
Stopped trying- a while later- I tried it, and worked fine.
Maybe too cold? I dont know.
Its worked fine ever since.
Old 11-15-2006, 11:48 AM
RozmerJJ's Avatar
RozmerJJ RozmerJJ is offline
Senior Member
2005 Chevy TrailBlazer LS
May want to check the switch on the brake pedal. I'm not 100% sure what the truck uses to determine if the brake is being applied so it may also be an issue with one of the brake light bulbs.
Old 12-16-2006, 09:38 PM
buckwheat04 buckwheat04 is offline
I was having the same problem on the TB that i just bought. (The cruise only controlled when it wanted to) While doing some other maitenace today, I found a hole in a vacume line, I put same tape around the vacume hose untill I can replace it, anyways, since then the cruise has worked wonderfully. Maby it is just going through one of the times that it decides to work, but I guess we will see.
Old 06-04-2007, 03:36 PM
garrettbowman's Avatar
garrettbowman garrettbowman is offline
2003 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
What line did you tape? I am having a cruise control problem as well
Old 06-04-2007, 04:37 PM
JMal's Avatar
JMal JMal is offline
Senior Member
Black TrailBandit 4.2L I6 4X4
I had a similar problem once too, but that was due to the shifter not being exactly on D, but a bit off. Still the gears worked, but the cruise didn't. Apparently there's a sensor on the shifter too...
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Cruise uses the brake light switch to monitor "foot on brake".
To the best of my knowledge, vacuum is not a part of the cruise system. It's all electric.
Ray
Old 06-04-2007, 08:28 PM
LineNoise's Avatar
LineNoise LineNoise is offline
Yeah these trucks are drive by wire. But it's possible, because there is a vacuum hose going to the throttle body.
I would lean towards the switch. Maybe try and disconnect the battery for 30 minutes to reset the computer.
Old 09-17-2013, 12:32 PM
snipe1080 snipe1080 is offline
2004 Chevy TrailBlazer LS
Hey Im new here and I have the same issue, this is probably going to sound dumb, but does anyone have a photo of the switch on the brake pedal?
Similar Threads
Strange Cruise Control Issue Socom Interior 6 02-06-2015 05:55 PM
cruise control problem chevydriverx2 General 15 03-01-2009 09:39 PM
Cruise Control - Heated Seats Socom Interior 13 03-22-2007 09:37 AM
Cruise control BLK60SS Interior 8 03-24-2006 08:30 AM
cruise control problem kboom36 Interior 6 07-09-2005 02:25 AM
