Memory Seats - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Interior
Interior Interior
Old 03-16-2005, 12:15 PM
WBLMN WBLMN is offline
Memory Seats
Has anyone had problems with the memory seats. Mine is either not working properly or I'm not programming it correctly. I have set the position for #1, but I can't set it for #2. Do I have to have the #2 key in the ignition to set #2 to seat position.
Old 03-16-2005, 01:10 PM
jdits7's Avatar
jdits7 jdits7 is offline
2003 Chevy TrailBlazer LT
This is what the owner's manual says:
Adjust the driver’s seat (including the seatback recliner and lumbar) and both of the outside mirrors to the desired position. Then press and hold button 1
(for driver 1) for three seconds. A double chime will sound to let you know that the position has been stored. A second mirror and seating position can be programmed by repeating the procedure with a second driver and pressing button 2 for three seconds. Each time button 1 or 2 is pressed and released while the vehicle is in PARK (P), a single chime will sound, and the memory position will be recalled.
If you use the unlock button on the remote keyless entry transmitter to enter your vehicle, the preset driver’s seat and mirror positions will be recalled if programmed to do so through the Driver Information Center (DIC). The numbers on the back of the transmitters, 1 or 2, correspond to the numbers on the memory controls.
The seat and mirror positions can also be recalled by placing the key in the ignition if programmed to do so through the Driver Information Center (DIC).
To stop recall movement of the memory feature at any time, press one of the power seat controls or memory buttons. Two personalized exit positions can be set by first recalling the driver’s position (by pressing 1 or 2), then positioning the seat in the desired exit position for that driver. Press and hold the button with the exit symbol for three seconds. A double chime will sound to let you know that the position has been stored. With the vehicle in PARK (P), the exit position for that driver can be recalled by pressing the exit button. The mirrors, power lumbar and recline positions will not be stored or recalled for the exit positions. If no exit position is stored, the default is all the way rearward. Further programming for automatic seat and mirror
movement can be done through the Driver Information Center (DIC). You may choose to either select or not select the following: Automatic seat and mirror movement when the vehicle is unlocked with the remote keyless entry,
automatic seat and mirror movement when a key is placed in the ignition, and
automatic seat movement to the exit position when the vehicle is in PARK (P).
Kinda long, sorry.
JD
Old 03-16-2005, 01:20 PM
04TBEXT 04TBEXT is offline
2004 Chevy TrailBlazer LS EXT
Unhappy PERSONALIZATION PROGRAMMING
WBLMN, What year is your T/B?...Some personalization features were deleted from the mid-year '05 models....
Old 03-16-2005, 01:25 PM
Sorry, I have a 2002 Envoy. I have followed the directions in the owners manual. I don't get 2 beeps when trying to program #2.
Old 03-16-2005, 06:19 PM
RKE PERSONALIZATION
WBLMN, I'll try to help you..please answer the following questions: 1.). Was any type of repair performed to the vehicle where your personalization settings were all of a sudden lost? 2). Are both of the transmitters used on a regular basis? 3.) Does the power door lock system work completely? 4). Do both of the transmitters lock & unlock the doors?...Please post your answers and I'll try to sort this out for you.
Old 03-17-2005, 09:43 AM
No recent repair has been done, I just picked up the Envoy 2 weeks ago. The #1 remote is used more frequently, only used #2 a few times. Yes the power door locks are working like they are supposed to. Yes both transmitters work just fine.
I'm taking it back to the dealer today for them to look at it. Hopefully they will make it right since I just got it 2 weeks ago.
Thanks
Old 03-17-2005, 06:53 PM
Problem fixed. It was a bad switch. The dealer covered the costs, so all is well.
Old 03-20-2005, 06:44 PM
XTREEME's Avatar
XTREEME XTREEME is offline
You are correct about the 05's no longer having the option to automatically go to the set position on the keyfob unlock. You now have to actually press the memory button on the door to go to your set position.
Very strange to have this option removed.
Old 03-20-2005, 10:14 PM
02EnvoySLE Guy 02EnvoySLE Guy is offline
Hey at least it won't scare the crap out of me that the seat starts moving every time you put in the key.... I went to move a friend of my mom's '04 SLT out of my way in our driveway and about thought the truck was trying to crush me!
Old 03-21-2005, 12:37 AM
henrywp henrywp is offline
Yeah, I asked about that on my 05 cause I was originally told that it worked and stuff and then they came back and said that it had been removed on the 05's, which is weird because the remotes that they give us are still labeled 1 & 2. They said that they had been having too many problems on some of the older models and it wasn't worth it anymore, so they took it out of the software. Well, I guess enough people have complained so now they are working on a newer software version for it that will allow it to work.
You may not post new threads
You may not post replies
Similar Threads
Keyfob - Memory Seats?? sabrecanuck Audio and Electronics 3 03-09-2008 02:38 PM
Memory Seats Revisited Bradc314 Interior 0 07-20-2007 03:58 PM
Adding Memory Seats? Roggie General 9 03-26-2007 11:31 PM
Memory Seats & Gauges gabe8496 General 7 02-24-2007 11:35 AM
Problems with memory seats Missy General 6 10-21-2006 09:03 AM
