Rear "clunk" sound upon acceleration - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-24-2006, 12:19 AM
joplin05tb joplin05tb is offline
2005 Chevy TrailBlazer LS
Hi all,
Have noticed a single "clunk" sound coming from the rear of my TB when doing a fast acceleration from either a slow speed or complete stop. Doesn't happen during slow acceleration. Mechanic recently checked the differential fluid levels and are fine. No other noises are present and it otherwise drives like a dream. Searched here for this topic and a few old posts suggest that TBs have intentional excessive driveline play or the driveline may need tightened up. Any thoughts? Appreciate the help.
Steve
Old 11-24-2006, 02:57 AM
DEZEL1's Avatar
DEZEL1 DEZEL1 is offline
2005 Chevy TrailBlazer LT
Mine does the same too. I agree there are some older posts but no one every came up with a solution.
I am @ 25000 mile but it was doing this at maybe 15000
05 TB LT 4WD
95 ? (other car is a 2000)
85 Chevy C10 Diesel 230k
Old 11-24-2006, 11:32 AM
APDMC6008's Avatar
APDMC6008 APDMC6008 is offline
2006 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
I changed the differntial fluid and my clunk went away (2002 TB, had about 65K on it at the time), was nasty black gunk. It's fine now.
You could also check your swaybar end links. I had some clunking/rattling up front from that, and I replaced all those and it went away.
In memory of PFC Dawn Tillman, County 138
Old 11-24-2006, 07:14 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Take a look at the u-joints, wear in this area will give a clunk. Try shifting from "R" to "D" (stopped of course), a clunk could mean u-joint of ring gear wear.
Old 11-29-2006, 08:11 PM
02WhiteWs6 02WhiteWs6 is offline
New Member
2006 Chevy TrailBlazer LS
Originally Posted by APDMC6008 View Post
I You could also check your swaybar end links. I had some clunking/rattling up front from that, and I replaced all those and it went away.
I just had my rear swaybar end links replaced under warranty for a clunk/rattle sound comming from the rear. Seems to have fixed it, but seems strange to me. This was at 4,000k
Old 11-29-2006, 08:39 PM
onewheeldeal onewheeldeal is offline
2002 Chevy TrailBlazer LS
Victory Red 4.2L I6 4X4
Clunk
If you have a locking rear differential it will make a clunk under harder acceleration. From either a stop or slow speed. My clunk became more noticeable around 20,000 miles or so. Changing the fluid will make it smoother and quiter for about another 30,000 miles. I changed mine twice in 92,000 miles. If you have more of a rattling/clunk when going over small bumps its caused by your swaybar end links. There's 2 in the front and 2 in the rear.
Old 11-30-2006, 04:04 AM
Audiojunky's Avatar
Audiojunky Audiojunky is offline
I too have noticed this. I am at 30,000 miles. I think it might be time to go to the stealer to have it looked at.
Old 11-30-2006, 11:15 AM
fireman2828 fireman2828 is offline
2004 Chevy TrailBlazer LT EXT
My 04 just hit 30,000 miles. When I go over a bump, like maybe a speed bump for example, or just a bump in the road it makes a clunk kind of like a door is not shut all the way. Would that be the sway bar end links?
How do you check these? Thanks for info, Brian...
Similar Threads
FINAL sway bar decision guide trailblazerdude Suspension 34 03-10-2017 01:16 PM
Rear spare tire carrier AlekG Off-Road 11 05-01-2009 08:09 AM
installing rear bumpstops ralph4u2c Suspension 0 02-12-2008 05:14 PM
Borla Dual Cat Back - Now Available Nicks07TBSS Exhaust Mods 41 01-01-2007 08:56 PM
Rear end fluid Dave OEM Issues 6 06-06-2005 12:15 AM
