sudden loss of gas mileage...WTF? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-28-2006, 02:49 PM
gordinho80's Avatar
gordinho80 gordinho80 is offline
2004 Chevy TrailBlazer LS
Before i picked up my Wester's Tune, i was getting 250 miles per tank on 87 octane...since the tune, i've been getting 270ish with 89 octane...
all of a sudden, i'm getting less, 240ish now with 89...WTF???
driving style hasnt changed...the only variable i see being an issue is the temp outside and/or the fact that its been 5k miles since my last oil change...
Mario -
OffRoadTB.com
Old 11-28-2006, 02:52 PM
RozmerJJ's Avatar
RozmerJJ RozmerJJ is offline
Senior Member
2005 Chevy TrailBlazer LS
All the oil companies are now starting to put out the winter blend of gas. This will cause your mileage to drop and remember that on cold days you will usually allow your car to warm up longer than normal and this to will cause a drop in mileage.
Old 11-28-2006, 02:55 PM
Nukedog's Avatar
Nukedog Nukedog is offline
Senior Member
2006 Chevy TrailBlazer LS
Graphite Metallic 5.3L V8 2WD
gordonho80 - Octane will not usually affect you MPG...
Different brands may a little bit but should be very similar.
Winter gas burns less effectively than summer gas.
Get some Techron in your system as clogged injectors kill gas mileage...
02 Busa 1397cc
05 ZX10R
08 Tundra DCRB 5.7
Old 11-28-2006, 03:40 PM
gordinho80's Avatar
yeah but such a big difference? wow...i'll get some techron to clean out the injectors...i just cleaned the K&N cone...also need to do that oil change...
Mario -
OffRoadTB.com
Old 11-28-2006, 03:46 PM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
going from ~270 to ~240 miles per tank is probably attributed to the ambient temp swings. Ethanol blended / winter gasoline can do it or maybe a pressure drop in your tires.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 11-28-2006, 04:18 PM
Rob Rob is offline
2003 Chevy TrailBlazer LTZ
What exactly is "per tank"? 17 gallons? 18 gallons? Running it dry each time? I doubt it. The only accurate way is to track the actual miles driven between fillups divided by the number of gallons you put in the tank. You can't go by a couple of tankfulls either. My average over 3000 miles before the Wester's tune was 16.18 mpg. My average for more than 10,000 after the tune is 16.82 mpg, or around 311 miles on an 18.5 gallon tank. Maybe I'm seeing a half a mile a gallon improvement with the tune.
Old 11-28-2006, 04:43 PM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
Make sure you inflate your tires. When it get's cold, your tires drop a few PSI
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
Old 11-28-2006, 04:48 PM
gordinho80's Avatar
now that you all mention it...my tires do look a tad low...
i'll have new tires in 2 days and i work from home the rest of the week so the TB will be sitting in the driveway for a few days...will be sure to properly inflate new tires...
Mario -
OffRoadTB.com
Old 11-28-2006, 05:32 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
yup I just checked my tires sunday morning after sitting all night.
26 psi is what I found all around. I bumped it up to 31. Doorjamb specs 32But I also noticed a slight decrease in gas mileage with winter fuel.
Old 11-28-2006, 05:51 PM
alvin@pcmofnc alvin@pcmofnc is offline
PCMForLess.com - Sponsor
2007 Chevy TrailBlazer SS (3SS)
Summit White 6.0L LS2 V8 2WD
yep, along with winter blends come cooler temperatures for those tires to sit at.
I have tire pressure monitors in mine. The other day I came out to it and the right side was 33 and the left side was 29. Reason? The sun was shining on the right side I guess. I drove a couple miles and both sides leveled out.
704-307-4227
Tuning, Battery Cable Upgrades, intakes, e-fan kits, transmission cooler kits and more!
Similar Threads
OEM Trailblazer, Envoy Electronic Visco Fan Clutches EuroPartsAmeric Basic Vendor GroupBuys 26 01-14-2012 02:54 AM
Qusetion's For Better Gas Mileage (MPG) Hauduin TrailBlazer SS Chat 26 06-17-2008 04:13 AM
fan clutch? webjoe98 OEM Issues 7 01-29-2008 05:43 AM
Loss of gas mileage Joefireman General 7 05-01-2006 01:05 PM
Gas mileage... Why? New to TB TrailBlazer / Envoy Chat 30 03-14-2006 10:26 PM
