Strange noise comming from front end - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 12-12-2006, 12:36 PM
02TrailblazerLS's Avatar
02TrailblazerLS 02TrailblazerLS is offline
It only does this sometimes...
when I make a hard left at lower speeds and turn the wheel all the way (like the kind of manuver you would make in a crowded parking lot), I notice a rubbing sound comming from the front right wheel. I have rulled out rubbing....so now I can't figure out what it is.
It is very noticable, but only if I am making a quick turn. If I start moving after I turn the wheel, there is no sound. it's odd because it is only on left turns and it is the right wheel.
Is there a way that I can quiet this down without consulting a mechanic? I sure hope it isn't a major suspension problem. A friend of mine's 02 Envoy does the same thing.....
Old 12-12-2006, 02:29 PM
chipper chipper is offline
2002 Chevy TrailBlazer LT
It could be a problem with the sway bar links in the front end, the GM ones are pretty crappy, I got mine replaced with some aftermarket ones recommended by my Mechanic, they are much stronger, but they were about $110 a side instead of the GM $60 per side.
-=Chipper=-
Old 12-12-2006, 05:37 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Have someone stand by that wheel while you turn the wheels. That will locate the noise. Then we can help to locate the problem.
Old 12-12-2006, 05:43 PM
joe70ss joe70ss is offline
Senior Member
2007 Chevy TrailBlazer LT
There might be rubber stops on thre frame that have to be greased,were on my 2001 Blazer
Old 12-12-2006, 06:02 PM
wheelieking wheelieking is offline
2004 Chevy TrailBlazer LS
I have exactly the same problem. mine seems to be connected to the amount of throttle i give it too. like it could be power steering pump failure but it is only when i turn left. sonds like a rub but nothing is rubing, or maybe vibration.
BTW: mine is an 04 ls with 53k
Old 02-28-2007, 10:26 PM
truex1 truex1 is offline
New Member
2003 Chevy TrailBlazer LS
i am having the same prob. seems like mine only happenswhen i am turning hard left and the suspension has to work (bumps, etc.).
did u ever figure out the problem? i have an '03 tb w/only 40k.
Old 02-28-2007, 10:43 PM
jaylind jaylind is offline
2007 Chevy TrailBlazer LS
Silverstone Metallic 4.2L I6 2WD
-=Chipper=-
I think you paid way too much..aftermarket are no more that $20 per side front or back. Upgrade to MOOG and they are maybe around $46 per side...Gm parts where closer to $80 per side.. I change my fronts in Nov and rears 2wks ago.
Do a search on link ends or sway bar
JAy
Old 02-28-2007, 11:35 PM
pogbobo's Avatar
pogbobo pogbobo is offline
Senior Member
2006 Chevy TrailBlazer LS
Question
I am new to the forum, I've only had my '06 TB LS for a couple of weeks ... anyway, when I make the turn into my apartment parking lot I hear a rubbing noise also (from the front drivers side tire), but mine is when I'm turning right... Its been driving me crazy and I don't want to take it to the dealer... I've also ruled out rubbing because there is no wear or marking visible.
Thanks in advance guys, this forum has been my number1 source for all my TB needs and I hope in the future I can contribute my experiences. -Matt
[Also, there are no aftermarket parts or upgrades yet, its still all stock]
Old 03-01-2007, 02:18 AM
Gearhead2012's Avatar
Gearhead2012 Gearhead2012 is offline
Sandstone Metallic 4.2L I6 4X4
Is everyone who is having this problem 4wd? sounds almost like a cv joint, vaguely. Otherwise...I don't have any guesses.
It's only reckless if you're not in control.
32" Nitto Terra Graplers/2" BDS/K&N CAI/Flowmaster 40 Series/Tuned PCM
Old 03-01-2007, 09:06 AM
New Member
mine is 4wd...and i just used it quite extensively due to lots of snow & a ski trip to even more snow.
also, i know the factory sway bar links are crap, but isn't the noise that comes from them more of a "rattle" and not a "clunking & squeaking" sound (yes, there is both)??? i have the latter sounds, and it only happens when i turn hard left AND hit a bump of some sort, or turn into my driveway (quite steep).
this problem is also alleviated when i dont turn the wheel all the way...if i turn it about 1-2 inches shorter, i hear no sounds at all...sounds like a joke i heard once..."hey, doctor, it hurts when i do this...doctor says, 'don't do that.'"
Similar Threads
Front end noise BikertrashNY General 14 04-12-2014 12:54 AM
Front end noise citycrosser OEM Issues 4 11-18-2008 05:09 PM
Bra now for the 06+ LT front end? Spong Exterior 12 11-11-2007 02:21 AM
2005 Trailblazer Rear End Noise - Pinion Bearings? waterskier98 OEM Issues 3 07-22-2006 11:45 PM
Front End Noise While Idling Kahunakai 02-09 Vortec 4.2L I-6 Engine and Drivetrain 6 06-26-2005 03:14 AM
