TRANSFER CASE FLUID? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-26-2005, 01:15 AM
thecarbonman thecarbonman is offline
2004 Chevy TrailBlazer LS
4.2L I6 4X4
Has anyone used anything other than GM fluid in their transfer case? I know there is a GM SPEC #, somewhere I thought I saw where AMSOIL has an oil they say will work. Any help on this subject. Thanks
Old 09-26-2005, 02:36 AM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
To my knowledge AMSOIL does not have a fluid that will work, and I am a preferred customer and get their newsletters. I put in AutoTrak II fluid, 2qts. You will have some left over in the bottles because they are liters, not qts. I will look into the AMSOIL fluid though, and get back to you on it, eventually!
Old 09-26-2005, 02:43 AM
Northwest Chapter
not here Other AWD
I looked at Amsoils website, and now see that they offer a fluid for the Transfer Case,W/ manual trc. I know this is not applicable to 4WD trucks, but it says for vehicles with this, you can use ATF. I know for my transfer case, NV226, only AutoTrak II will work.
Old 09-27-2005, 12:57 AM
Wxman Wxman is offline
2003 Chevy TrailBlazer LT EXT
5.3L V8 4X4
Maybe Redline MTL
FWIW
I haven't changed out the transfer case yet, but am a fan of Redline products. According to their 'cheat sheet':
GM Automatic Transfer Case Fluid, GM PT# 12378508 (Blue), can be replaced with Redline MTL (Manual Transmission Lube).
Good luck
Wxman
Old 09-28-2005, 12:04 AM
4.2L I6 4X4
Thanks for the input on this, I guess I'll just go with GM fluid then add IXL METAL FRICTION PROTECTOR, I have never had to change the transfer case oil on my NP208 since adding IXL, the ATF is still clear red after 65,000 miles. Before I was changing it every 25,000 miles because it was turning black.
Again THANKS.
Old 10-04-2005, 10:12 PM
4.2L I6 4X4
Originally Posted by Wxman
FWIW
Good luck
Wxman
After further research I going with you Wxman. I did contact Redline Corporate and they said the MTL would meet GM specs but because GMs fluid is blue, to save any problems to wait until warranty had expired to change. That is from Redline. This B.S. of manufactures forcing people to buy from them because they claim only theirs works, not to mention they hold you hostage by charging a big price, pisses me off. Because of that I won't buy GM S--T if it is a dollar a quart and was not for sure that was how I was going to go in the first place. We owned a Dodge and they did the same crap, being an old mechanic I remember when we put FORD type F in everything, so I contacted an old tranny shop in Vegas and they are now putting DEXRON in everything. GEE that Dodge worked great after they servicing it and adding DEXRON. I drove it 40,000 before buying our TB no troubles. According to Dodge Mopar-4 was needed. @ $9.00/QT vs DEXRON @ $2.00/QT. Enough out of me, if you didn't get it that's OK.
Old 10-08-2007, 06:15 PM
Tom1999d Tom1999d is offline
2002 GMC Envoy SLE
Sandstone Metallic 4.2L I6 4X4
Transfer case fluid
The fluid is only $6 per quart and you need 2 quarts. For $12 I'm not going to worry about buying GM Brand.
Amsoil SVG is a good substuite for the GM synthetic Differential oil in the front (1 qt) & rear Differential (2qts).
No matter what change these fluids at least every 50 k miles if you want your truck to last.
Old 10-09-2007, 10:15 AM
Bearcat's Avatar
Bearcat Bearcat is offline
2004 Chevy TrailBlazer LT
Don't blame GM or Dodge for making a fluid that works, blame the rest of the manufacturers out there for not making a product that meets spec!
All's well that ends well!
Old 10-19-2007, 04:34 PM
Customgod227 Customgod227 is offline
Graphite Metallic 4.2L I6 4X4
This might sound like the worst question in the world. But is there a way you can check the front and rear diff fluid? I have never owned a rear-wheel drive vehicle, and am unsure if you can do this, and if you can, where to check it. Thanks for the help!
Old 11-15-2007, 08:18 PM
jD_Empath jD_Empath is offline
2002 GMC Envoy SLT
Fire Red 4.2L I6 4X4
Bringing the thread back to life....
You can check the oil in your diffs by removing the fill plugs located about halfway up. Stick your finger in and feel for the level of the oil. It should be at least within 1/2" of the fill hole. If the fluid is black and not nice and oily, change it.
Similar Threads
? fluid capacity transfer case & front differential JPNNH 4x4 Drivetrain 2 09-01-2013 05:57 PM
Why no 4 by 4 switch? Vader AWD Drivetrain 25 03-02-2010 10:00 PM
Transfer case fluid change.....episode gmcman 4x4 Drivetrain 30 01-14-2010 10:29 AM
Transfer Case Fluid Change (Automatic Transfer Case Only) Trefilov22 4x4 Drivetrain 8 01-11-2010 05:24 PM
Shudder, Rocking Motion, Binding, Feels Like Vehicle is Stuck in 4WD mickdigler 02-09 Vortec 4.2L I-6 Engine and Drivetrain 9 10-02-2006 11:38 AM
