MAP sensor - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-30-2006, 10:48 PM
blue11 blue11 is offline
New Member
MAP sensor
I just took the wifes 02 trailblazer to the dealer for a CEL coming on off and on.
they told me it was the map sensor intermittly causing it to go on and off and replaced it.
anyone have any information on the MAP sensor????
thanks
Old 12-30-2006, 11:44 PM
cliffwilson's Avatar
cliffwilson cliffwilson is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
The Manifold Absolute Pressure (MAP) sensor is attached to the intake manifold. Electrically, it is a potentiometer, using the standard three wire configuration of a 5 volt reference circuit, a low reference circuit (ground), and MAP sensor circuit signal. The voltage signal to the PCM relative to the 5 volt reference provides the vacuum state of the intake manifold. Also, prior to cranking, its signal establishes barometric pressure. The data is used by the PCM to assist in fuel management. The MAP signal is coordinated to a table of expected values for throttle position and engine speed. When the MAP signal is outside the predicated ranges, a DTC (Diagnostic Trouble Code) will be set.
Old 12-31-2006, 12:26 PM
New Member
great thanks cliff, sounds like it does have a lot to do with gas milage then so the dealer was telling me the truth.
thanks
Old 11-15-2008, 09:18 AM
tomsmith tomsmith is offline
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Hey all,
Can someone post a pic of where the MAP sensor is located? my 2004 TB LS is throwing a P0106 code
I've cleaned the throttle body but it's still there
Many thanks
Old 11-15-2008, 07:34 PM
brendanpower's Avatar
brendanpower brendanpower is offline
Senior Member
2007 Chevy TrailBlazer LT
Moondust Metallic 4.2L I6 4X4
On top of the intake. See the red circle in the attached Picture
Brendan,
PCMFORLESS Tune, CAI, HID's, PIAA's, Mirror Signals, Glasspack & Tip
Old 11-15-2008, 09:07 PM
Black 4.2L I6 4X4
Thank you very much brendanpower
I'm guessing I'm OK to clean this with throttle body cleaner or electronics cleaner (I have a spray thats specifically designed for autmotive electronics)?
I'm a little new to this board, can someone recommend a good online retailer for parts (the MAP being the first )
I tried creating a new thread, but guess I haven't reached the threshold yet
Old 11-16-2008, 09:39 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
MAF Sensor Cleaner is more effective, but i guess throttle body cleaner would work too. just a thought.
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
Old 12-04-2008, 01:12 AM
wardak33's Avatar
2002 Olds Bravada
just wondering, but have you fixed your problem yeT?
Old 12-31-2008, 09:59 AM
shelrandy shelrandy is offline
gmc envoy GMC Envoy SLE
Cranberry Red Metallic 4.2L I6 4X4
shelrandy new to the forum
hello all I have a 2006 gmc envoy and it shut down whille driving
GMC dealer says the only bad part on the vehicle is a bad map sensor
my car has been thru every computer diagnostic all show no issue
we replaced the PCM no help no O2 sensors or catalytic convertewr..no fuel pump issues no wiring issues..
I am hoping the map sensor is my problem 2 solid days in the shop my wallet is hurting.. oh yeah and 3000 miles out of warranty..http://forums.trailvoy.com/images/smilies/frown.gif
Old 12-31-2008, 08:12 PM
wardak33's Avatar
2002 Olds Bravada
MAP sensors could cause problems like that. I just recently replaced mine, and it wasn't that hard to do. If the dealer says its the sensor, i'd go with their opinion. They use a tech2 scanner, which tells them EVERYTHING. hope this helps. and if you need help with the MAP sensor, just let me know.
Similar Threads
Remove alternator to change Thermostat? mastermonkhabib Engine Tunes/Mods 141 03-24-2015 08:21 AM
How do I change a MAP sensor on my 2002 Tblazer LS kota Air Induction 2 03-10-2008 06:35 PM
MAP sensor location? jdwest Air Induction 7 02-19-2008 12:37 AM
Oxygen Sensor readings xceebeex OEM Issues 6 01-09-2008 11:41 AM
Map Sensor McKinley 02-09 Vortec 4.2L I-6 Engine and Drivetrain 1 04-22-2007 04:31 PM
