loud noise when accelerating...help - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > OEM Issues
OEM Issues Original Equipment Repairs/Problems
Old 01-09-2007, 10:16 AM
dv_tbss06's Avatar
dv_tbss06 dv_tbss06 is offline
2006 Chevy TrailBlazer SS
Summit White 6.0L LS2 V8 2WD
well its been like a week now every time i get on the gas pedal its starts making this noise like if two metals where hitting together... something like clak clack clak clak clak clak clak clak ....something like that !!! and when i have the truck in park and revv it up i can hear it on the passanger sides wheel and underneath.... so i tought it was the torque converter since its a tci went yesterday to the transmission place i got installed on and the seperate it it from the fly wheel and it was still making that noise so we figuered it was the flywheel...so i purchased the tci flexible fly wheel and will put it in today...see if it still makes that noise ! im guessing if the noise still continues it will most likely be a piston since iam spraying a 100 shot
tune,ud pulley,e fans,k&n intake, 160 t stat.
Old 01-09-2007, 10:38 AM
Liquiddi's Avatar
Liquiddi Liquiddi is offline
Senior Member
that's not good. Engine is probably on its way out.
06 Silverstone Metallic TBSS (sold)
07 GC SRT8
05 C6 Vette
Old 01-09-2007, 11:02 AM
dv_tbss06's Avatar
thats what im guessing that it might be the engine but whats with that motor knock everybody is talking about ?
Old 01-09-2007, 11:52 AM
dv_tbss06's Avatar
if its the pistons wouldnt u hear them once the truck is on and at idle ??? u can only hear this when i accelerate it
Old 01-09-2007, 02:38 PM
Liquiddi's Avatar
Senior Member
how does the truck run? Does it run normal or is theri a loss of performance? Maybe a bad coil pack or something like that. You might want to pull the spark plugs on that side and take a look at them. Have you ever overrevved the engine past redline?
07 GC SRT8
05 C6 Vette
Old 01-09-2007, 04:34 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
hmmmmmmm
Just as an FYI...
had a 70 Monte Carlo with a 350 and 4brl carb.
when you accelerated hard, or launched hard from a stop, youd hear this loud clank clank clank clank clank, real fast.... in reverse I could burn rubber no problem.
the problem was traced to a broken engine mount.
on hard starts, the torque actually lifted the engine enough on one side that the metal fan blades hit the fan shroud.
changed the mounts.... and alls been well now for years.
Old 01-09-2007, 08:11 PM
dv_tbss06's Avatar
the truck runs at its best.... and yes it passes the red line ! i think it hits the red line and a little over......maybe a bent pushrod or what ? spark plugs are good changed them yesterday to ngk tr6...they were red
Old 01-09-2007, 10:53 PM
TBCOPPER TBCOPPER is offline
It is it clank or a click? I have a click click that is coming from the rear of my car and the dealer said it was the Driveshaft which is geoing ot be replaced this week. If its coming from the rear, might be the same problem. If it is from the front, sorry i cant help you.
Old 01-10-2007, 12:17 AM
Liquiddi's Avatar
Senior Member
how loud is this? I mean is it like hitting a hammer against the side of the car or is it just a tick??
07 GC SRT8
05 C6 Vette
Old 01-10-2007, 12:29 AM
TonyGXP's Avatar
TonyGXP TonyGXP is offline
Silverstone Metallic 6.0L LS2 V8 2WD
well, Mine made that noise and it was my TCI converter.. but you say it made the noise when it was seperated? are you sure? Lifter? exhaust leak up near the manifolds? was it on the lift while it was running? 100 shot? I bet you broke a Piston then.. none of the plugs showed any damage? maybe a small crack? Saw that before on an LS1 after it was run too lean, made a noise like you're describing too..
2WD TuneTimePerformance Tuned SS
CAI, 3200Vig, UD, Efan.. 12.5's all day long
You may not post new threads
You may not post replies
Similar Threads
Loud Noise ma2169 General 15 01-20-2011 01:08 PM
Loud Clicking Noise from Steering Column Ron_texas Interior 9 05-12-2008 05:14 PM
2 issues knocking noise and loud pop noise too~ sumerl OEM Issues 4 03-21-2008 11:18 PM
LOUD fan noise with CEL and Reduced Power Issue sizemoreracing OEM Issues 5 02-14-2008 12:07 PM
Loud vibration noise underneath while idle!!?? Got5onIt General 6 12-27-2006 12:02 AM
