Vacuum line missing - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain
02-09 Vortec 4.2L I-6 Engine and Drivetrain Q&A forum for engine and drivetrain repairs/modifications/tuning.
Old 01-19-2007, 04:06 PM
Mud's Avatar
Mud Mud is offline
2002 Chevy TrailBlazer LT
4.2L I6 4X4
Vacuum line missing
I just did the throttle body cleaning and while I was in the middle of it I noticed I had a missing vacuum line. I'm not sure where it goes.. anyone tell me? I'm wondering if this has to do with my engine every once in a while almost stalling when I come to a stop.
MagnaFlow Exhaust, K&N Intake, Fuzion XTI's
Quick reply to this message
Old 01-19-2007, 04:23 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
the stalling- are you running your AC and coming to a stop when it does this?
Old 01-19-2007, 04:31 PM
Mud's Avatar
Mud Mud is offline
4.2L I6 4X4
More then likely yes but I can't say I'm 100% positive. It's never actually stalled it just drops down to ~ 100 RPM then it kicks up again. What are you thinking the problem could be?
Old 01-19-2007, 04:34 PM
TrailBlazer LS's Avatar
TrailBlazer LS TrailBlazer LS is offline
Senior Member
2004 Chevy TrailBlazer LS
My 04 I6 has a vacum plug on it. So it does nothing on the 04's i don't know if your 02 is the same. I don't know about the stalling. Sorry. Good luck. Mark.
4x4. G80. 3.73's. K&N fipk2. PCMforless tuned. Dyno Max ultra flow mufflers. Debadged. Sold 5-3-08.
Old 01-19-2007, 05:03 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
I think I heard somewhere that vac stub powers an HVAC actuator for EXT models. Not sure though. My 2005 LS has a cap over it. Mine doesn't appear to pull a vacuum with the cap removed, but I'd cap it anyway. You can get rubber caps in bulk hardware depts or auto stores.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 01-19-2007, 05:44 PM
rbarrios's Avatar
TrailVoy Guru
I had a problem on my 03.
Where at stops- and slow turns- with AC on, would couse the engine to idle erratically, or sometimes shut off.
If stationary. I could see the RPMS be normal at 600 with AC off. Turn AC on and RPMS would go to about 100-200, engine vibrate a bit, then rush up to about 1000, back down to 100 or so, and up.....it went on like this as long as the AC was on. You could heard the AC compressor cycling on and off too. when going faster- the RPMs would not move as much, but I could feel the engine losing and gainin power.
Turns out I had changed battery few days before.
The fix- disconnect battery, clean throttle body, and reconnect battery after at least 30 min.
this cleared memory or bad learned settings. When I used it again after the above, it worked like new. no drop in RPM when AC is turned on.
try it.
put vehicle in Drive. turn on AC, and note the tach..... whats it do?
in my case. installing battery cause it to lose memory, when I used the AC again, it learned settings with a dirty throttle body and it didnt know what to do. When AC came on- it tried to compensate by adding more gas- but butterfly was slow... so engine almost dies, by the time the added gas does reach- it causes the surge, but the conpressors has shut off because it sensed the engine wanting to turn off.....
so thats why it cycles up and down.... like its stuck in a loop.
Old 01-19-2007, 06:17 PM
blktbon20s's Avatar
blktbon20s blktbon20s is offline
2002 Chevy TrailBlazer SS
Jet Black 4.2L I6 4X4
you know that skinny hose u have to the intake, well that little 90 degree vacuuum line i connected it to where u r wondering what it is
look at my pic
Trailvoy has the one and only GG AKA GiG
Old 01-19-2007, 06:21 PM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
If you put your finger over it, you'll feel it sucking in air and that raises your RPM by a bit. On my EXT, there's a hose that's connected to it and it runs all the way to the rear left firewall. I think it's a vacuum line for the EGR valve or something
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
Old 01-20-2007, 03:15 PM
cliffwilson's Avatar
cliffwilson cliffwilson is offline
Summit White 4.2L I6 2WD
The port pulls vacuum on my 05. I've checked it with a gauge. Therefore, it should be capped. While it serves no functional purpose on my TB, it's a convenient point for vacuum testing.
Old 01-24-2007, 02:13 PM
rbarrios's Avatar
TrailVoy Guru
blktbon20- I noticed on mine- that little 90 degree thingy is connected to the 4200 piece of plastic- and my other nipple is capped.
You may not post new threads
You may not post replies
Similar Threads
Vacuum line missing? MDNUC General 4 06-14-2008 05:03 PM
Very odd vacuum issue... neelskit OEM Issues 4 05-05-2008 09:09 PM
Missing vacuum line? aw OEM Issues 6 12-09-2007 11:43 AM
The adventures of glue and his power steering pump ieatglue 02-09 Vortec 4.2L I-6 Engine and Drivetrain 25 12-06-2006 09:22 PM
