check engine light code # p1441 what is it - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 01-24-2007, 01:22 AM
thriller thriller is offline
2002 Chevy TrailBlazer LT EXT
Question check engine light code # p1441 what is it
I had the check engine light on a 02 TB with about 140K on it. I scanned and got the p1441 code ( EVAP system flow during non purge) I cleared the code but can anyone explain to me what that code was all about? THANKS
Old 01-24-2007, 04:55 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
If you are really lucky you can go and check your gas cap and it will be loose or you forgot it at the pump.
Other than that check your gas tank for leaks from the sending unit or the filler neck.
Good luck!
B.
Bill
Let's get a Meet going!
Old 01-24-2007, 12:50 PM
vball61 vball61 is offline
2002 GMC Envoy SLT
Onyx Black 4.2L I6 4X4
Excerpted from the service manual:
DTC P1441
System Description
This DTC tests for undesired intake manifold vacuum flow to the Evaporative Emission (EVAP) system. The powertrain control module (PCM) seals the EVAP system by commanding the EVAP purge valve OFF (closed) and the EVAP vent valve ON (closed). The PCM monitors the fuel tank pressure (FTP) sensor to determine if a vacuum is being drawn on the EVAP system. If the vacuum in the EVAP system is more than a calibrated value within a calibrated time, DTC P1441 will set.
Conditions for Running the DTC Test
DTCs P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0440, P0442, P0446, P0452, or P0453 are not set.
The ignition voltage is between 10-18 volts.
The barometric pressure (BARO) is more than 75 kPa.
The fuel level is between 15-85 percent.
The engine coolant temperature (ECT) is between 4-30°C (39-86°F).
The intake air temperature (IAT) is between 4-30°C (39-86°F).
The start up ECT and IAT are within 9°C (16°F) of each other.
The vehicle speed sensor (VSS) is less than 121 km/h (75 mph).
Conditions for Setting the DTC
A continuous open purge flow condition is detected during the diagnostic test (fuel tank pressure decreases to less than -11 inches H2O).
Conditions for Clearing the MIL/DTC
The PCM will turn the MIL OFF during the first trip in which the diagnostic has been run and passed.
The history DTC will clear when the PCM turns OFF the MIL.
The DTC can be cleared by using a scan tool. "
Old 01-24-2007, 06:09 PM
Menthol's Avatar
Menthol Menthol is offline
2003 Chevy TrailBlazer LT EXT
Pewter Metallic 4.2L I6 4X4
Link for codes
http://www.troublecodes.net/OBD2/Pcodes.shtml
Old 01-27-2007, 04:00 PM
Talking
THANKS GUYS!!! I cleared the code and removed and reinstalled the gas cap. I have not seen the code come up again.
Old 12-14-2007, 07:29 PM
hoezaycuervo hoezaycuervo is offline
2002 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
P1441 Code
I am resurrecting this thread because I am getting this code. I have check the gas cap and made a conscious effort to make sure I screw it on tight. The code will go away when I have a full tank, but once I get down to about 2/3 of a tank it cuts on. Does anyone have any suggestions on where to start to correct the system? Could it be a bad sensor? Should I have my EVAP system smoke tested? How much $ would that set me back? Any insight is appreciated!
BTW- I have 111K miles...
Old 12-14-2007, 07:32 PM
rubberman's Avatar
rubberman rubberman is offline
2004 Chevy TrailBlazer LS EXT
Dark Gray Metallic 4.2L I6 2WD
maybe try a new gas cap
2004 TB EXT I6 CAI, PCM4Less PCM, Resonator delete, Kuhmo KL51
Old 12-14-2007, 07:53 PM
jedi_jr's Avatar
jedi_jr jedi_jr is offline
2011 Chevy Silverado
Imperial Blue Metallic 5.3L V8 4X4
My parents 2003 had this problem and it wasn't the Gas cap. We had to remove all evaporative hoses and put rtv on the ends to seal them and then it went away.
Old 12-07-2014, 12:10 PM
KarmaLeigh561 KarmaLeigh561 is offline
Angry code p1441
i bought a 2002 chevy trailblazer about 4 weeks ago, the car worked fine for 2 days before it started idling low and just cutting off at redlights, the check engine light came on and i had it read code came up as p1441 , it has now been in the shop 3 different times for a total of 12 days. the dealer insists on sending to his mechanic as hes paying for it, however the first time they replace the throttle body, canister and filler tubes. i got the car back after 3 days and it was still idling low shutting off at redlights and check engine light came back on after 2 days same code. took the car back and they insisted it was the throttle body replaced it again. this week was the 3rd time replcaing the throttle body. im not a mechanic but at this point im sure im being screwed. can anyone tell me what is causing this code and my car to idle low and shut off? the throttle body has now been replaced 3x, the canister once, the filler tubes an gas cap. and this is still happening to me.
Similar Threads
Stabilitrak off, check engine light and reduced engine power light after kick down isalti OEM Issues 3 05-08-2012 03:17 PM
Secondary Air Intake Engine Code nathnn99 Air Induction 15 06-14-2011 01:24 PM
Check engine light came on froggman55 OEM Issues 3 12-08-2007 07:45 PM
undate on my check engine light thor OEM Issues 21 09-23-2007 03:12 PM
Check Gauges/Service Engine light Flashes benashlee OEM Issues 15 02-28-2007 07:50 AM
