Check Engine & Reduced Engine Power Light came on WTF!! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-06-2007, 03:32 PM
dallas03 dallas03 is offline
2003 GMC Envoy SLE
Pewter Metallic 4.2L I6 4X4
Ok... I live in North Dakota and yesterday it was -30 degrees out!!! I have a block heater so the mornings have been alright, but at work i cant plug the voy in. After a 12 hour shift and being -17 degrees out all day, i went to start the voy and it started really weird and the check engine and reduced engine power light came on!!! I let it warm up for 10 min and then shut it off. I started it and the reduced engine power light shut off but the check engine light remained on. My question is... has anyone experianced this and know what it means? I was also wondering what the engine is doing when that light is on, because it didnt want to rev-up, just wanted to idle.
Old 02-06-2007, 03:39 PM
MTPockets's Avatar
MTPockets MTPockets is offline
2005 Chevy TrailBlazer LS
4.2L I6 4X4
Usually, when the RP light comes on with the SES light, it's a throttle by wire issue. Especially if you have no/limited throttle response. Maybe the accellerator pedal position sensor (up above gas pedal) got wet? Other than that, the motorized actuator and throttle position sensor is built into the throttle body itself.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 02-07-2007, 05:22 PM
LTZTrailblazer LTZTrailblazer is offline
2002 Chevy TrailBlazer LTZ
I had the same thing happen to my TB. I live here in Northern Minnesota. The problem on mine was some moisture got into the resonator box and froze and after it ran for a while it was fine, but you might want to pull the resonator box off and check if there is any ice in there. Just an idea.
Old 02-07-2007, 05:23 PM
Chances are it wsa probably just really cold.
Old 02-08-2007, 03:20 PM
2003 GMC Envoy SLE
Thanks guys.
It was because it was so cold. Everything is fine now.
Old 02-08-2007, 03:37 PM
ghoster ghoster is offline
2011 Chevy Tahoe
Mocha Steel Metallic 5.3L V8 4X4
Joel
Hey Joel,
Does the throttle by wire run through a check at start up?? I mean does it actually move the throttle a little and verify position? I would think if it was really cold and their was a little moisture around the actuator( and it froze) it might not be able to verify its postition and throw a code and the RP light. I ask cuz mine did this once after being driven in a nasty ice storm then being parked for many hours. Once it warmed up, I restarted it, and everything cleared up..... almost everything. The window washer fluid stayed frozen for 2 days.
Old 02-08-2007, 06:08 PM
MTPockets's Avatar
4.2L I6 4X4
Originally Posted by ghoster View Post
Hey Joel,
Ghoster, I'm sure it goes through some type of self diagnostics for safety reasons. Dunno how or what though. I know the accelerator pedal position sensor and the throttle body position sensor have to match positions (stay calibrated) or the system will basically s/d and throw the engine into reduced power mode. Like you say, a extremely cold TB may stick. If it sticks, the sensors wont line up, truck goes in reduced power mode.
Joel
Old 10-20-2008, 05:26 PM
llong llong is offline
BLUE 6.0L LS2 V8 4X4
My reduced engine power light and service engine soon light come on when i first start my truck...after it warms up the reduced engine light goes off...i took the truck to auto zone and got a p0601 code...can someone please tell me what is going on with my truck. thank you in advance for any help
Old 10-20-2008, 07:17 PM
Super 88's Avatar
Super 88 Super 88 is offline
2005 Chevy TrailBlazer LS EXT
Short version - most likely your PCM or "computer" is bad.
http://forums.trailvoy.com/showthrea...ght=p0601+code
Edit: It would help us if you included the year of your vehicle and the engine especially in your user profile.
Old 10-30-2008, 02:59 PM
Help
My Reduced Engine Power Light Comes On When It Is Cold Out...(while That Light Is On I Can Not Go Any Faster Then 10mph)i Have To Let The Truck Warm Up For About 1/2 Hr Turn It Off And Start It Back Up Then The Light Goes Out But The Service Engine Soon Light Is Still On....can Anyone Tell Me What Is Going On And How Can I Fix This Problem Please!!!!!!!!!!!! I Already Had My Fan Clutch Replaced. Thanks In Advance
Similar Threads
SES and Reduced Engine Power light on WayFastWhite OEM Issues 46 12-23-2014 07:34 PM
Check Engine and Reduced Power light? Trefilov22 OEM Issues 11 06-01-2012 09:48 PM
Gen IV 5.3 LH6 Info... Windy City Engine Tunes/Mods 7 08-08-2006 11:41 AM
05 TB DOD status? muddy tires 02-09 Vortec 4.2L I-6 Engine and Drivetrain 19 07-28-2006 11:00 PM
Vector tuning = Check engine light?!?! TBSSTony Engine Tunes/Mods 45 01-30-2006 12:08 PM
