stabilitrak fuse quick help - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > OEM Issues
OEM Issues Original Equipment Repairs/Problems
Old 02-09-2007, 02:57 PM
cgseanp cgseanp is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 2WD
I am getting my truck dynoed soon, can someone tell me where to find the stabilitrak fuse so I can disable it for good on the dyno??
I did a ton of searching but couldnt find it!
thanks
Old 02-09-2007, 03:01 PM
CARBONGSXR's Avatar
CARBONGSXR CARBONGSXR is offline
Senior Member
Silverstone Metallic 6.0L LS2 V8 2WD
thanks
did you look in the manual?? i know theres a diagram of the fuse box in it. also, check the box itself all fuses should be listed and numbered. hope this helps.
DRIVE FAST, TAKE CHANCES
Old 02-09-2007, 03:08 PM
alvin@pcmofnc alvin@pcmofnc is offline
PCMForLess.com - Sponsor
2007 Chevy TrailBlazer SS (3SS)
Summit White 6.0L LS2 V8 2WD
thanks
Its one of the big fuses first row (i think 3 over) in the underhood fuse panel. Its labed ABS I believe.
704-307-4227
Tuning, Battery Cable Upgrades, intakes, e-fan kits, transmission cooler kits and more!
Old 02-09-2007, 04:13 PM
Jeremy Jeremy is offline
Black 6.0L LS2 V8 AWD
I believe it's fuse #61, VSES.
Old 02-09-2007, 05:03 PM
ADM PERFORMANCE ADM PERFORMANCE is offline
ADM PERFORMANCE
DONT KILL YOURSELF TRYING TO FIND OUT WHAT FUSE!
Just unplug the front wheel speed sensor,mounted to the frame right behind the front wheel.....very easy.
Been doing cars for years that way!
Andy
For what it is worth - It throws a code and disables the traction control and stabilitrac due to the code.Plug it in when your done and your good.
Old 02-10-2007, 12:50 PM
thanks for the help
I got it done but didn't pull any fuses, just held the button in for a while until it was fully disabled and did not have any issues.
I made 335hp and about 350tq with only a volant CAI and no tune.
Old 02-10-2007, 03:08 PM
CARBONGSXR's Avatar
Senior Member
good numbers.. congrats.
can you post a the dyno graph??
Old 02-10-2007, 08:25 PM
I'll try to get it done later, I don't have a scanner so maybe I can do it at work.
Similar Threads
Cig Lighter fuse location? tombellanca General 7 01-17-2012 09:47 AM
Po455 AND Diagnostic Port / Cig Fuse blows??? Ron78Z66Vette OEM Issues 4 11-06-2007 07:48 AM
IGN E fuse blowing atlsooner General 5 05-31-2006 05:20 PM
Front Parking Lights - Fuse? Blulytes Exterior 9 07-26-2005 09:19 PM
