Bolt pattern & offset help - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Brakes, Suspension, Wheels and Tires > Rims
Rims Rims and Wheels on your TrailBlazer SS
Old 02-22-2007, 02:47 AM
jack0278's Avatar
jack0278 jack0278 is offline
2007 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
Which if any of the 24's would fit under a stock SS? I'm not sure on the BOLT PATTERN(MM), and the OFFSET(MM).
Old 02-22-2007, 07:47 AM
TrailblazerSS's Avatar
TrailblazerSS TrailblazerSS is offline
Senior Member
2006 Chevy TrailBlazer SS
Silver 6.0L LS2 V8 AWD
The TB bolt pattern is 6/127 (or 6 lug 5"). Those are the wrong bolt pattern.
As for offset it depends on wheel width. Maximum backspacing is about 145 MM (5.9"). That sets maximum offset to:
8" = 46 MM
8.5" = 40 MM
9" = 34 MM
9.5" = 28 MM
10" =22 MM
06 TB SS...98 Camaro SS... 07 Cobalt SS
Old 02-22-2007, 09:21 PM
travd travd is offline
Make sure you want to spend $600 each on China made foose wheels? I had a customer come into my work with basically that same Foose wheel and on the back of it said made in China. I can see spending that much on a "one off billet" wheel from Foose but not store bought China made cast wheels from him.
Old 02-22-2007, 10:30 PM
ltz03's Avatar
ltz03 ltz03 is offline
Summit White 6.0L LS2 V8 AWD
umm actually most rims are made in china!! from crappy ones to the top dogs most are made from the same material usually the same factory!! there are some which are made here and are very good. our SS wheels are made there too
tuned,kooks LT,SW catback,ADM cai,3200 vig,ported tb,efans. 13.2@101mph 1.71 60'
Old 02-23-2007, 10:13 AM
BuffaloSS BuffaloSS is offline
Wow...24s on an SS? Going to add some unsprung weight on that thing, huh? Not a performance freak LOL
Old 02-23-2007, 10:07 PM
jack0278's Avatar
Thanks all for the help and advice!
Ya I think 24's would look nice.. I will just have to make up for the extra weight by adding extra HP
I wouldn't think they would add very much weight.
Anyone know what kinda extra weight they would be?
What does the stock rim weight?
Old 07-19-2007, 09:04 PM
iamkhanz iamkhanz is offline
2002 SAAB 9-7x
Light Pewter Metallic 6.0L LS2 V8
I have some really nice 20" wheels they are HRE wheels for the Trailblazer/Envoy they are custom made for the Trailblazer/Envoy with correct bolt pattern.. They are high polished 20" 3 piece wheels and you know HRE's are very light also.
Old 08-16-2007, 01:48 PM
corvettemick corvettemick is offline
Black 6.0L LS2 V8 2WD
Question on Off-set
8" = 46 MM
8.5" = 40 MM
9" = 34 MM
9.5" = 28 MM
10" =22 MM
What would a 20" with a 24 mm off-set do? Just move the tire further to the outside of the TB?
TIA,
Mick
Old 08-17-2007, 06:52 PM
Senior Member
Yes. Smaller offsets move the wheel out.
Old 08-17-2007, 10:19 PM
Darkside's Avatar
Darkside Darkside is offline
Superior Blue Metallic 6.0L LS2 V8 AWD
I'm in Cleveland as well. Can you PM me your bottom line you want? Is it wheels/tires or just wheels. Thanks.
Similar Threads
Change TBSS wheel bolt pattern to 6 on 5.5" ? Fud Rims 2 08-13-2015 09:15 PM
Bolt pattern supergeess Rims 6 08-21-2007 04:24 PM
Is Changing the Bolt Pattern a Problem? BUC NASTY Rims 11 03-16-2007 03:57 PM
03 Bolt Pattern Different? 03Blaze Rims 4 03-15-2007 03:17 AM
Has anyone tried adapters for bolt pattern? JJKJ Rims 4 11-01-2006 05:44 PM
