Flasher Module Relay - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 02-28-2007, 08:54 PM
CREVZ21's Avatar
CREVZ21 CREVZ21 is offline
2004 Chevy TrailBlazer LS
Silver Mist Metallic 4.2L I6 4X4
I'm looking to install LED turn signals all around the TB. I have searched the site and haven't found what I'm looking for. I want to know exactly what flasher module I need to purchase. I don't want to use the inline load resistors. There are different set-ups of modules what one do i need.
Old 03-01-2007, 06:29 AM
APDMC6008's Avatar
APDMC6008 APDMC6008 is offline
2006 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
I could be wrong, however I think most people just tapped into the regular wires? They didn't buy another flasher I don't think....
--Chris
In memory of PFC Dawn Tillman, County 138
Old 03-01-2007, 08:37 AM
Bearcat's Avatar
Bearcat Bearcat is offline
2004 Chevy TrailBlazer LT
I have seen a flasher module for LEDs on the v-leds.com website. This may give you an idea of what to look for. Switching to LED turn signals without adding a load resistor, or changing the flasher module will result in the lights (LEDs) not flashing properly.
All's well that ends well!
Old 03-01-2007, 08:58 AM
Envoy Fan's Avatar
Envoy Fan Envoy Fan is offline
TrailVoy Guru
2005 GMC Envoy Denali
Summit White 5.3L V8 4X4
Where is the flasher module located that needs replacement?
BILL
Old 03-01-2007, 09:18 AM
Bearcat's Avatar
It's located behind the left closeout/insulator panel. which itself is located under the steering column. Not to be confused with the hazard flasher, which uses a relay and would not be affected by the LEDs.
Old 03-01-2007, 04:36 PM
CREVZ21's Avatar
Which flasher do we need?
2 Pin Electronic LED Flasher Blinker Fix
3 Pin Electronic European LED Flasher Blinker Fix
3 Pin Electronic LED Flasher Blinker Fix
Old 03-01-2007, 04:43 PM
Envoy Fan's Avatar
TrailVoy Guru
Locate the flasher module and remove it. Take a pic.
If it has two pins it will take the two pin flasher. If three pins the three pin flasher. We can assume it is not the European one. So it is two pins or three pins, depending on what you already have.
BILL
Old 03-01-2007, 05:19 PM
Bearcat's Avatar
Only sure way to do it.
Old 06-21-2007, 07:15 PM
CREVZ21's Avatar
I know it has been a while with this post. I haven't had time to put the lamps in until Tuesday Night. I finally got around to looking for the flasher relay today. I can't find it. Does anyone know where it is? I have been reading around and for an 02 it is in the Fuse Box Under the hood, and 03 is under the steering column. Does anyone know where I could find it on an 04. If anyone also knows if it is a 2-pin or a 3-pin that would be great.
Old 06-22-2007, 08:04 AM
Bearcat's Avatar
It's mounted to a bracket on the inside of the left closeout/insulator panel, which is below the steering column.
Similar Threads
Rear wiper problem ninesevens10 General 11 09-23-2013 12:55 PM
LED Flasher Module wmolzon Audio and Electronics 6 07-23-2008 10:28 AM
Flasher Relay Problem! Info please Mainevent24 Exterior 3 04-07-2008 10:17 PM
Ignition in the Passkey Module NateTheGreat11 Audio and Electronics 2 06-13-2007 11:47 PM
2003 GMC Envoy XLT: Where is the Location of the FLASHER RELAY Jill General 11 10-13-2005 10:02 PM
