headlights dimming - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 03-12-2007, 01:07 PM
michiganTB's Avatar
michiganTB michiganTB is offline
2005 Chevy TrailBlazer LS
headlights dimming
So last night i was on my way home, i had been driving for about 15 minutes on surface street sthen hit the freeway, when i ws at my exit another 15 minutes away, the headlights started dimming whenever i would hit the breaks. the didnt go out the would just pulse, it was like they were being drained of power and then would get it back. the dash lights were also dimming and the voltmeter was dropping aswell. it never dropped below ~12 or so and i havent driven yet today. Anyone have any ideas they would be appreciated.
Old 03-12-2007, 01:27 PM
mgawlik1 mgawlik1 is offline
2007 Chevy TrailBlazer SS
Silverstone Metallic 6.0L LS2 V8 2WD
If you were losing power while driving, there very well could be an issue with your alternator. I had that happen once to me too, eventually it got too low to even drive. I would definatley have it checked out along with the battery too.
Old 03-12-2007, 01:31 PM
dtown's Avatar
dtown dtown is offline
2002 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Old 03-12-2007, 10:19 PM
cc56259's Avatar
cc56259 cc56259 is offline
may just check to see if you have a good ground still sometimes the y loosen up and cause similar problems.
Old 04-03-2007, 10:12 AM
briant73 briant73 is offline
I have noticed my headlights dimming/flickering at night also. I usually notice this at highway speeds when I let off the gas, the lights seem to flicker/dim a lot.
I am under warranty but if it's a ground cable loose I can check that but where are the grounds on the Trailblazer?
Old 04-03-2007, 10:31 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
Follow the negative Battery terminal lead to it's ground point. Check and clean both ends.
Look for the Engine block to frame ground then clean and re-tighten both ends. Also check the Alternator connections for tightness.
B.
Bill
Let's get a Meet going!
Old 04-03-2007, 10:26 PM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
To the owners with the dimming/pulsing lights while coasting at speed, did this happen for you while it is wet out? My 2005 LS has done this, but only in the rain. I've yet to find the culpret connection.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 04-03-2007, 10:32 PM
michiganTB's Avatar
for me it didnt happen in rain and it has only happened a few times since. the different times have been as follows
1- highway speed let off gas to exit and as i came up the ramp th headlights and dash lights dimmed and the voltmeter dropped to just under 14
2- same thing but driving around city doing no more than 50
it seems like it only does it when the car is decelerating(sp) but there is no brake applied. i havent even checked any of the wires because it has been such an infrequent problem but i think i may check them tomorrow.
Whats the worst scenario that this could be?
Old 04-03-2007, 10:38 PM
MTPockets's Avatar
4.2L I6 4X4
Originally Posted by michiganTB View Post
..it only does it when the car is decelerating(sp) but there is no brake applied.
Yep, same EXACT thing here. The dash lights & headlights pulse big time, but the engine never so much as stumbled or varied in RPM's. I havent gotten it to replicate in a few weeks. I hate those problems!
Joel
Old 04-04-2007, 09:47 AM
My problem is very similar, highway speeds, let off gas, watch the lights flicker.
I disconnected the battery last night, checked all the ground connections I could find in the engine bay, reconnected the battery (have your keys nearby when reattaching the negative since mine set off the panic alarm but simple keypress on the fob corrected).
Drove on the highway let off gas and watched for it and no problem seen, but the problem is intermittent. I wonder if there is a TSB for it?
Joel
Similar Threads
Dimming Flickering headlights markhart1 General 38 03-22-2011 09:20 AM
dash lights, headlights dimming cokoliso General 38 08-02-2010 01:42 PM
Headlights dimming when let off gas? Customgod227 Audio and Electronics 2 11-25-2007 08:09 PM
Headlights dimming? lawman6558 General 0 05-15-2007 06:15 PM
Headlights dimming on startup SilverTrail General 1 03-05-2007 04:13 PM
