I have a tapping sound in my TB's I6! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-12-2007, 02:36 AM
greasy pete greasy pete is offline
2004 Chevy TrailBlazer LTZ
Tan-ish 4.2L I6 4X4
Actually, it might be a lifter? I don't know - it's got full oil, and taps pretty noticeably when warm and cold. It's a 2003 TB 4.2 I6 with 104k... any thoughts, any feelings, any suggestions? I'm not much of a mechanic but I am not intimidated unless something is very complex.
Old 04-12-2007, 02:39 AM
ghoster ghoster is offline
2011 Chevy Tahoe
Mocha Steel Metallic 5.3L V8 4X4
We don't have lifters as such. Mine taps too. Its mostly from the fan clutch. Though the injectors can be a bit noisy.
Old 04-12-2007, 07:51 AM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
There are actually hydraulic lifters in this motor; but their called Valve Lash Adjusters
Anyway, There are a couple of bulletins related to Valve Lash Adjuster noise, but it's not common to see them fail. The more probable source of your noise is your fuel injectors ticking away. It's been noted by some other members that the plastic intake (on our trucks) actually amplifies this noise. Get a piece of small hose or a long screwdriver and place it up against your ear; put it up against each injector and listen. You'll probably find a few of your injectors are really noisy...nothing to be too concerned about.
Let us know how you make out
-Mike
AKA PROVY
Rock On!
Old 04-12-2007, 10:09 AM
justblazin's Avatar
justblazin justblazin is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
try to narrow down where the tapping is coming from.. If it is coming from the intake, it could be your injectors
Old 04-12-2007, 01:22 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
Ill agree with injectors.
open the hood and you can hear them. tick tick tick tick
Old 04-12-2007, 06:08 PM
Knightslugger's Avatar
Knightslugger Knightslugger is offline
2004 Chevy TrailBlazer LS
Graphite Metallic 4.2L I6 4X4
i don't have to open my hood, i can hear it if i roll the window down!
PCM4Less.com Tune (mild)
De-racked
quad-beam'd
Old 04-12-2007, 07:16 PM
rbarrios's Avatar
TrailVoy Guru
ohhhhhhhhh. I only hear if I open hood...
u must really have a noisy one
Old 04-13-2007, 01:39 AM
psu_nuc psu_nuc is offline
New Member
2002 Chevy TrailBlazer LS
Black 4.2L I6 4X4
I have a similar problem and I have seen this injector explanation a few times. How loud would the injectors actually tap? I can easily hear a tap under acceleration and at idle especially if my windows are closed. Would the volume of the tap change with engine temp similar to a valve/lash adjuster tap? Thanks.
Old 06-30-2007, 10:44 PM
dionmckinney dionmckinney is offline
New Member
tapping
I had to have my exhaust manifold gasket replaced. Made one hell of a difference.
Old 07-01-2007, 09:39 AM
MichEnvoyBoy's Avatar
MichEnvoyBoy MichEnvoyBoy is offline
2002 GMC Envoy SLT
My 2002 Envoy's I6 (99,800 miles) has a very loud tick that comes and goes. Its normal... we have a DOHC setup with clicking fuel injectors and a fan clutch that loves to
b!tch at us...lol
"Envoyaholic"
2002 Envoy SLT Autoride, Navigation, Dark Blue. 152,000 miles. Purchased 10/2004
Similar Threads
OEM Navigation: More Info Than You Could Possibly Want to Know Murp4099 Audio and Electronics 395 08-08-2016 12:12 AM
If you're the TBSS guy that helped me out today, PM me...Here's my race story 02-Bravada-88 Racetrack Results 51 11-03-2013 03:42 PM
Help the Roadie design a new back seat area the roadie Off-Road 89 11-03-2008 12:18 PM
First good race...it was a draw Blue Beast Racetrack Results 6 03-30-2007 01:21 AM
