Removing factory radio - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-12-2007, 11:25 PM
jose2782 jose2782 is offline
2004 GMC Envoy SLT
Monterey Maroon Metallic 4.2L I6 4X4
Question Removing factory radio
I have an 04 Envoy and I just purchased a Pioneer AVIC-D3 head unit. I wanted to know, how do I remove the factory radio? And no, it does not have Bose or DVD. Is there also special adapters to make the head unit work? Your help would be very helpful to me.
Old 04-12-2007, 11:32 PM
jaylind jaylind is offline
2007 Chevy TrailBlazer LS
Silverstone Metallic 4.2L I6 2WD
Start under the drivers side dash. 2 screws bottom then 2 on top. remove that pannel. now remove the 2 screws that you just exposed. look at speedometer there are 2 screws above it. Drop the Tilt steering wheel down al the way. down by the 12v power outlets remove 1 screw. Place parking brake on. turn key so you can put the transmission in 1st gear (this gives you some room to work). Now start pulling on the dash bottom right by the 12v power outlets working up and left. you will need to unplug the 2 12v outlets connectors. then the wiper switch and the 4wd is you have 4wd. then al the way to the left disconnect the headlight switch. after all thats out of the way there are 3 screws holding radio in and pull it out disconnect antenna and 2 connectors on the radio.
JAy
Old 04-13-2007, 12:01 AM
LineNoise's Avatar
LineNoise LineNoise is offline
2003 Chevy TrailBlazer LS
http://forums.trailvoy.com/showthread.php?t=6459 <~ Diagrams
http://forums.trailvoy.com/showthread.php?t=1479 <~ Adaptors
There's a sticky at the top with the diagrams.
On the envoy it looks a lot easier then the trailblazer since you don't have to drop the knee panel and remove the headlight switch and fight with the steering wheel.
Old 04-13-2007, 12:43 AM
tomvoy's Avatar
tomvoy tomvoy is offline
Senior Member
1992 GMC Jimmy
Jaguar Blue 5.3L V8 2WD
I had the panel out where the radio is and I had to remove console because there is two screws below outlets behind the center console.
Old 04-13-2007, 10:35 AM
APDMC6008's Avatar
APDMC6008 APDMC6008 is offline
2006 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
Removing the console fascia is rather easy. Reinstalling it is a major fargon pain in the azz.
In memory of PFC Dawn Tillman, County 138
Similar Threads
What OEM HU's work in what years? orangedawg Audio and Electronics 8 03-30-2009 07:55 PM
Question about factory Radio camarofreak85 Audio and Electronics 10 10-27-2007 11:31 PM
factory radio crazytb Audio and Electronics 3 05-08-2007 12:36 AM
Bose Radio replacing the factory amp acworld Audio and Electronics 1 03-28-2007 07:40 PM
CD changer for a factory TS Nav Radio? upirons Audio and Electronics 5 01-05-2006 08:41 PM
