Camshaft Install Kit for 6.0 L LS2 2007 Engine Applications - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Engine tuning and/or modifications
Old 04-18-2007, 12:45 AM
MileHighSS's Avatar
MileHighSS MileHighSS is offline
2007 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
Question Camshaft Install Kit for 6.0 L LS2 2007 Engine Applications
Ok guys or venders.. I have a Q. DO you absolutely need to upgrade to this 3 bolt conversion kit to run a new Cam in the 2007 LS2 SS
"On the new 2007 LS2 engines Chevrolet has gone to a single bolt camshaft sprocket design and uses a spring-loaded chain tensioner. To install the earlier style camshaft with the three-bolt sprocket you need this kit. Kit includes three-bolt sprocket, chain damper & camshaft bolts. The damper is installed with the original bolts from the chain tensioner."
It seems that LPE didn't have the best answer. Or a answer that would merit another couple of hrs in shop time to swap to new 3 bolt set up. The shop said that the kit seems that the technology went backwards on this one.Is their slop in the chain if you don't do the conversion?.Can any one please chime in..again this is on the 2007 LS2.
Frank
Old 04-18-2007, 08:18 AM
FASTONE27's Avatar
FASTONE27 FASTONE27 is offline
Black 6.0L LS2 V8 2WD
Frank
Frank... You need to call my buddy's at Vengeance Racing in Cumming Georgia! Mike & Ron will take care of you! I believe I can say that I am probably the first one in the country to do a cam swap in an 07 TBSS. No kit needed!
Old 04-18-2007, 11:06 AM
MileHighSS's Avatar
Thanks i'll give em a call
Old 04-18-2007, 11:24 AM
FASTONE27's Avatar
I just PMed you!
Similar Threads
Remove alternator to change Thermostat? mastermonkhabib Engine Tunes/Mods 141 03-24-2015 07:21 AM
code p0014 Jbird13329 OEM Issues 11 03-05-2014 08:41 PM
Anyone in Philadelphia Area able to change actual mileage? TrailinAlong517 TrailBlazer / Envoy Chat 10 11-13-2009 06:43 PM
Gen IV 5.3 LH6 Info... Windy City Engine Tunes/Mods 7 08-08-2006 10:41 AM
05 TB DOD status? muddy tires 02-09 Vortec 4.2L I-6 Engine and Drivetrain 19 07-28-2006 10:00 PM
