Unknown Driver Message - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-22-2007, 01:16 PM
MrCowman MrCowman is offline
New Member
Angry Unknown Driver Message
2003 TB 120k miles decided overnight the key we have always used won't work, neither will spare key, get Unknown Driver message, car now DOA. What has caused this? How to rectify?
Old 04-22-2007, 01:18 PM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
Probably a bad ignition switch Do you get any lights at all when you try starting it?
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
Old 04-22-2007, 01:22 PM
New Member
Key turns, all the normal dash lights come on, get the unknown driver message and nothing else happens
Old 04-22-2007, 02:17 PM
Crossroader Crossroader is offline
Did a search on this board and other boards, and it possibly might be related to a short within the IPC (Instrument Panel Cluster), or even the BCM or RKE.
How's your battery?
Tried jumping it?
Have you tried disconnecting the battery for a while to see if the problem goes away?
Old 04-22-2007, 03:19 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
It sounds like the pass-key security has disabled your ignition. This normally prevents an unauthorized key from starting ur truck. Things that will cause ur key to not work are water and/or grease on key or in the ignition switch. If those things don't help, try disconnecting the battery for 10 min., might reset something.
Ray
Old 04-22-2007, 06:29 PM
vball61 vball61 is offline
2002 GMC Envoy SLT
I agree that it looks like a failure in the theft deterrent system, but Trailvoys contain Passlock security, not PassKey. Passlock consists of a hall-effect sensor and tamper resistor within the ignition cylinder housing, while the PassKey system uses a transponder in the ignition key head.
Passlock isn't affected by contamination of the key, but there are a number of things that can cause it to fail - high or low voltages, problems with the Passlock circuits, module communication failures...
Your best bet is to have the diagnostic trouble codes pulled - there are at least eight associated with Passlock failure.
Old 04-22-2007, 08:05 PM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
Have you recently added any accessories? Jumped the vehicle/battery died?
-Mike
AKA PROVY
Rock On!
Old 04-22-2007, 08:33 PM
RayVoy's Avatar
TrailVoy Guru
Black 5.3L V8 4X4
Thanks vball61, I knew the keys were different, but did not know they were now different systems. What is in the key that hand-shakes with the cylinder electronics?
Ray
Old 04-22-2007, 08:54 PM
Envoyguy05's Avatar
Envoyguy05 Envoyguy05 is offline
2006 GMC Envoy SLE
Cranberry Red Metallic 4.2L I6 4X4
there is an exciter on the igintion cylinder that is part of passlock. That maybe your problem
Old 04-23-2007, 03:11 PM
2002 GMC Envoy SLT
Nuthin'. It's just a plain ol' ignition key.
There's a magnet in the ignition cylinder, which, when the key is rotated, triggers a Hall effect sensor in the ignition cylinder housing, enabling the body computer to read the voltage across the tamper resistor.
If somebody attempts to force-rotate or slam-pull the ignition cylinder, the tamper resistor is (in theory) destroyed.
Similar Threads
Driver Controls Do Not Work!! SkiBum Interior 29 12-19-2009 01:12 AM
UNKNOWN DRIVER? Car won't start? John02Trailblaz OEM Issues 2 06-09-2008 09:25 PM
unknown driver? dansk OEM Issues 5 12-23-2007 04:05 PM
Driver Door Buttons all dead!!! tmetal Interior 3 11-26-2007 06:16 PM
Unknown Dirver related to tailgate???? timmayee General 4 11-30-2006 06:36 PM
