Tire Pressure Monitor Warning Light. HELP! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Tires
Tires Tires
Old 04-28-2007, 12:05 AM
shaky1977 shaky1977 is offline
New Member
I have 2007 trailblazer LS. and it came with Tire Pressure Monitor Standard. Now I have changed the rims and tires and already sold my original 17 inch rims and tires. I have yellow Tire pressure monitor yellow warning light in dash all the time , Its just like check engine light. Now from reading posts i understand cluster lights are soldered . But is this light soldered or its just a bulb? I am sure its not LED bulb because it blinks like regular bulb. I dont want anything to do with cluster lights, i am only talking about the warning yellow light, Can i just open the unit and take that bulb off? or something? Basicaly i wanna get rid of that light from my sight, i dont care about tire pressure monitor sysytem. Or is there a fuse i can just take out? My TB LS does not have driver information system. so that annoying light how to get rid off? please please Help me.
And i dont wanna buy new sensors and nor they will fit my new rims.
Thanks.
Old 04-28-2007, 01:06 AM
ltbuick's Avatar
ltbuick ltbuick is offline
2003 Chevy TrailBlazer LT EXT
Dark Green Metallic 4.2L I6 2WD
You May Have To Go Back To Dealer. The Monitor Works By Counting Rotations Of The Tire, Almost The Same Way Abs/traction Does. It May Have Been Set To Factory Rims And Tires And You Are Slightly Out Of The Normal Program.
Old 04-28-2007, 03:36 AM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
you went with bigger rims?
did the overall diameter stay the same as the OEM tire?
Since he said it counts revolutions- what it does is use the ABS sensor.
of all tires are the same size they all rotate at the same rate.
once the tire begins to lose air its diameter changes... so if it loses air, the tire gets smaller and this it spins more than the rest. the ABS sensor picks this up and signals a problem. so if the overall diameter is the same.. MAYBE you can reset it and get the problem to go away.....
I thought the monitor was like the one on my 07 Impala, where it has sensors in the tire, and sends signal via the remote keyless module. My sisters 03 Impala uses the ABS sensor method to signal an alarm
Old 04-29-2007, 01:55 PM
titanium10k's Avatar
titanium10k titanium10k is offline
2007 Chevy TrailBlazer LT
Imperial Blue Metallic 5.3L V8 4X4
Yes the tire pressure monitor is wireless. They are inside your old rims. Your gonna have to go to the dealer and get them to possibly deactivate if they can.
07 TRAILBLAZER LT 4X4 V8 3.73 SUNROOF G80
02 SILVERADO 5.3 V8 G80
Old 05-01-2007, 10:47 PM
AHM1973 AHM1973 is offline
2006 Chevy TrailBlazer LT EXT
First off there is no way to disable the TPM system,and even if there was a dealer is not gonna do that.Why would you want to do that anyway?You will need to buy 4 TPM sensors which are the valve stems.Then you will need to have a dealer program the sensors to your truck.It is not a big deal at all I have done it plenty of times with aftermrket rims.
Old 05-02-2007, 09:47 AM
Gary UT's Avatar
Gary UT Gary UT is offline
Sandalwood Metallic 4.2L I6 4X4
The dealer will not disable the TPM system. As a result of the Firestone/Explorer tire proplems every new vehicle is required to have a TPM system.
http://en.wikipedia.org/wiki/TREAD_Act
Gary
Old 05-02-2007, 04:13 PM
vball61 vball61 is offline
2002 GMC Envoy SLT
Onyx Black 4.2L I6 4X4
The sensor part number is 25774006. Be prepared to pay at least $30 each. You'll also need the nut which clamps the sensor to your rim - p/n 15825474.
You can program the new sensors to the truck yourself - the procedure is in your owner's manual, under "TPMS Sensor Identification Codes" (pg. 462).
Similar Threads
Good tire PSI? DangerousTacos General 51 10-28-2007 06:10 PM
Tire pressure and towing ?'s cgriffin_5139 Tires 2 07-17-2007 05:01 PM
Tire Pressure Sensor Warning CopyGuard Tires 36 10-18-2006 05:44 PM
How many forum members does it take to change a light bulb? Sport_truck Everything Off-Topic 4 08-09-2006 05:37 PM
Tire Pressure Sensor P/N(s) frankies_2 Tires 3 01-10-2006 12:53 PM
