P0401 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > The Lounge > Everything Off-Topic
Everything Off-Topic A place to post pics, videos or to talk about anything, NOT RELATED to TrailVoys. (Please use good judgement)
Old 04-28-2007, 01:27 PM
hatchet669's Avatar
hatchet669 hatchet669 is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT
P0401
ok this is on my fathers ford ranger... i got this code P0401 which is EGR Flow Insufficient... so what do yall think i need to do exactly... i was gunna check the EGR module and just check sensors... what ya;; think?
Old 04-28-2007, 03:51 PM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
You might want to clean the EGR valve It's probably just clogged up
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
Old 04-28-2007, 03:53 PM
hatchet669's Avatar
TrailVoy Guru
yea that is what i was thinking... just wanted other insight on what yall think and what sensor it mite be that need to be changed or cleaned... thanks glue
Old 04-28-2007, 03:56 PM
ieatglue's Avatar
TrailVoy Guru
The school's 94 blazer had that problem too. We took it off and cleaned it up with some brake cleaner. Remember to remove it gently as to not destroy the gasket
Old 04-28-2007, 04:09 PM
hatchet669's Avatar
TrailVoy Guru
i forgot i have a manuel that i bought for my truck... old mzada pick up that works for the for ranger... it mentions in there what sensors and all that in there... thanks...
Remove the EGR valvs and clean the inlet and outlet ports with a wire brush and scraper, Do no sandblast the vlave or clean it with gasoline or solvents. These Liquids will destroy the EGR Valve diaphragm.
what it says in teh book... so is brake fluid cleaner considered a solvent or no?
Old 04-28-2007, 04:16 PM
ieatglue's Avatar
TrailVoy Guru
I don't know. You've gotta break down that carbon somehow anyway. Maybe soak it in some seafoam
Old 04-28-2007, 04:25 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
I don't think a new value is very expensive, might be cheaper than the cleaner
Ray
Old 04-28-2007, 04:53 PM
hatchet669's Avatar
TrailVoy Guru
around 40 bucks at autozone.com
