Battery cable replacement... - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-11-2005, 10:44 PM
APDMC6008's Avatar
APDMC6008 APDMC6008 is offline
2006 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
Think again. It's a major PITA. My replacement AC/Delco battery was leaking and had corroded the Pos battery cable fitting so badly, I knew I was going to have to replace it. Anyways, I figured I would let it go until I had the time and the money to fix it. In another thread someone stated I should go and replace the cable in addition to the battery. Last week the battery died when I was cleaning the inside of the truck, and today it died when I was working on the doors. Well, I figured I shouldn't risk getting stranded and I went to a store that carried the positive cable ($40..AC/Delco PN 4SX402FSA). Well, I drove 20 mins there and when I went to leave...nothing. Didn't even crank once, and everything died...click click click. So I got a friend to give me a ride to Pep-Boys to get a battery (AC/Delco 78DT) and then we went back and jumped the truck off and I got home, loaded up some tools and went to the fire dept where I could do it indoors. When I got there I shut it off and it refused to start not even one minute after I shut it off. Battery was D-E-A-D dead.
Now for the fun part . I disconnected the Neg and cut off the positive, since it was so corroded I couldn't even break torque on the bolt. Removed the old battery and got to work disconnecting the cable from the alternator and the starter. First off...the damned bolt for the alternator would be easy to get to, but all the harnesses from the PCM, etc are right over it. It took some contorting but I got that one off somewhat easily. The starter one is a PITA . You can't really see it or reach it from above. I had to jack up the truck and slide under it and take it off by feel. Then I had to undo all those little cable clamps. I found that the battery acid had indeed permeated the entire cable, as there was discoloration and evidence of corrosion in the cable all the way to the ends...so it made me glad that I replaced it. Installation is just as big a pain as removal, but at least you know where the clips are, etc. It took me about 4 hours. Truck started on the first try and everything is fine.
Only question is...when I start it now, sometimes the truck drops reallll low on RPMs for a second, is this normal for it to relearn its settings? It was without any power for over 4 hours.
In memory of PFC Dawn Tillman, County 138
Old 11-11-2005, 10:59 PM
dach95's Avatar
dach95 dach95 is offline
yeh, it take a little time to relearn for the PCM to relearn. don't worry about that. good job in fixing the power. I would be a little freaked if my tb wouldn't start...
-D A C H 9 5 - 2002 Chevy TrailBlazer 4X4 LTZ EXT Summit White
4.2L I6, 3.73 rear ratio Airaid CAI Poweraid TBS Mobil1 Full Synth-ACDelco PF61 Optima YellowTop (Fried) Sylvania Silverstars (1 side blew) RPL'd with GE Nighthawk Infinity Burl dash AVS In-Channel Deflector, it's a LTZ
Old 11-11-2005, 11:02 PM
jimmyjam's Avatar
jimmyjam jimmyjam is offline
TrailVoy Guru
2006 Chevy TrailBlazer SS (LT)
White 402ci Other AWD
I've never seen a starter that was easy to get to.. had to swap the wires in my last blazer. the trick to doing the alternator is having a long enough extension so you can just go underneath the ECM
Think of it this way, the next time you do it, it'll be a snap!
Old 11-11-2005, 11:04 PM
APDMC6008's Avatar
I hope there won't be a next time!!! Hopefully everything will iron itself out and it'll be back to normal. It's very disconcerting hopping in your car and turn the key and...click click click. Glad it didn't happen out in the middle of nowhere at night or something.
Similar Threads
Battery Replacement caused AC problem? cocomobile General 21 07-02-2012 04:33 PM
Replacement Battery ? ilikemy3s OEM Issues 16 01-05-2008 08:17 AM
Battery replacement and TCCM issues redgar00 General 1 01-09-2007 12:35 AM
Rumour about Battery Replacement ??? SharkVette General 7 10-25-2006 08:15 PM
Battery cable breaking off wookiee2cu General 14 10-19-2005 08:16 PM
