Relocating IAT Sensor, need help with parts - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > Air Induction
Air Induction Performance Air Intake/Air Induction Modifications
Old 05-06-2007, 03:33 PM
cgseanp cgseanp is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 2WD
So I want to try to relocate my IAT sensor. I would just buy the HSRK from vector but I'm broke and figured I'd try this out. So can someone help me out with parts? This is what I found so far..
https://www.casperselectronics.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=108136&Categ ory_Code= thats the maf/iat breakout harness from the 05-06 GTO. I think its the same for our trucks?
Casper also sells the IAT extension harness. Would I need something like that to put the IAT sensor by the airbox?
And do I need to buy a new sensor or can I use the stock one? I know the stock sensor isnt a quick reactor or whatever, I just want to put it in a cooler location.. assuming this is safe??
I'm at work or else I'd go outside and look at my truck to get a better idea of how this all works.
Thanks!!
Old 05-06-2007, 03:49 PM
bigjohn141's Avatar
bigjohn141 bigjohn141 is offline
Summit White 6.0L LS2 V8 2WD
You cannot use the factory sensor because it is built into the MAF. Check on ebay, I believe there is a cheaper version of vectors HRSK that comes with the harness and sensor. It has a different sensor that vector so it wont be fast acting but will let you relocate it to a different spot.
ADM TUNE, 100mm CAI, 160 THERMO, UDP
"I've got one life to live...Lets get it over with."
Old 05-06-2007, 03:55 PM
thanks, i thought I read somewhere that the sensor was built into the MAF. Ill check out ebay later, cant go there at work. If I were to build my own though, would I Just need the harness I originally posted, and an extension, plus a new sensor?
thanks again
Old 05-06-2007, 04:33 PM
BlackLS2 BlackLS2 is offline
Black 6.0L LS2 V8 AWD
I'm 99% sure that you have the correct breakout harness. I'm guessing that the IAT end would be long enough without an extension if you were going to the duct or maybe even to the end of the filter. Maybe a quick email to the harness supplier would give you an exact length and a suggestion on an IAT sensor.
Old 05-06-2007, 04:41 PM
ok cool I'll give them a call.
Similar Threads
Calling all envoy/Trailblazer owners who have or had cluster problems projectpete19 TrailBlazer / Envoy Chat 132 05-02-2011 03:04 PM
Where do you guys go for performance parts...? 400HPGTO Engine Tunes/Mods 7 07-28-2007 08:36 PM
LSX Shootout! Santa Ana, CA TXSS West 0 04-23-2007 09:27 PM
GM replacing paint with plastic film on more parts Greg Latest GM News 0 02-07-2006 07:12 AM
