4WD Indicator Lights Flashing... - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-12-2007, 09:41 PM
Wake's Avatar
Wake Wake is offline
2002 Chevy TrailBlazer LTZ
Black 4.2L I6 4X4
My 02 isn't a daily driver so it does sit occasionally for a week or two at a time without being driven... Yesterday, I drove it and did my normal routine, start vehicle, idle in park while I walk to the end of the street for my mail...
I come back and the vehicle must have been running for about 3-5 minutes when I notice that all the indicators for the 4WD switch are flashing and the N indicator is lit solid...
I looked at it for a minute or so before trying the switch to see if it would help, which it did after I switched from 2HI to A4WD and back... It took a little bit, but seemed to work...
Anyone seen this one before??? Stuck actuator maybe??? I was thinking that maybe these vehicles might cycle the actuator for the transfer case on startup as a diagnositic... Is this possibly what I saw trying to happen???
Old 05-12-2007, 11:08 PM
MtnManTB's Avatar
MtnManTB MtnManTB is offline
2005 Chevy TrailBlazer LS EXT
Graystone Metallic 4.2L I6 2WD
I had the exact same problem with my 2003 TrailBlazer LS 4.2L I6 4x4, which is the vehicle I drove every day before getting the 2005 I have now. I took it in for service and they had to replace that switch there on the instrument panel. Service advisor told me that they had replaced quite a few of these at that time, which was around December of 2004. On mine, the lights would flutter between 2WD and 4WD. After the 4WD light would stay on for a few seconds, the 4WD would actually engage. I wish I could provide you with the actual part number off the service order (it was repaired under warranty), but I threw all of that away when I bought my new '05.
Old 05-13-2007, 02:36 AM
Envoyguy05's Avatar
Envoyguy05 Envoyguy05 is offline
2006 GMC Envoy SLE
Cranberry Red Metallic 4.2L I6 4X4
yes a very common problem
Keith
Northeast Chapter MA Rep
K&N 63 Series, 6000k Hid lows and fogs, Magnaflow Cat -Back, 20's, G80
Old 05-13-2007, 07:33 PM
Wake's Avatar
Black 4.2L I6 4X4
Really??? I did a search before I posted and it didn't provide much...
So, fix, leave alone, bad switch, bad actuator??? Someone throw me a bone here...
Old 05-14-2007, 03:40 AM
MtnManTB's Avatar
My problem was a bad switch. I would take it to a Chevy dealer and have them repair it. I did not like the idea of it putting unnecessary wear by cycling back and forth all of the time. Now, mine was under warranty, but I would still have it repaired if I were you.
Just my 2 cents!
Old 05-14-2007, 05:10 AM
AKIRA's Avatar
AKIRA AKIRA is offline
Onyx Black 4.2L I6 AWD
It may be a problem of soldering.
Old 05-14-2007, 07:09 AM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
Wow! Nice pic AKIRA! What a horrible design that board is. You would be better off breaking the circuits too close to the pins and soldering jumper wires in, provided there is enough room.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Similar Threads
Another 4wd question clr114 4x4 Drivetrain 9 06-28-2010 12:23 AM
Expecting too much from 4WD? superman_79065 4x4 Drivetrain 72 07-16-2008 01:52 AM
Light flashing on the 4wd selector switch. Birdman275 Interior 3 08-03-2007 01:12 PM
4wd Service light issues if it help you guys out Shortbord1 4x4 Drivetrain 0 02-08-2007 02:43 AM
4WD Service light on, replaced TC Motor and more??? jkeating86 4x4 Drivetrain 3 06-17-2006 11:00 PM
