Dexcool disappearing from reserve!?! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-19-2007, 10:09 PM
nvmatrix nvmatrix is offline
2007 Chevy TrailBlazer LT
Just bought my 2007 TB and was checking things out and noticed Dexcool was low in the reserve tank. So I bought some 50/50 and top it off. Check it two days later and most of it is gone!!! What the hell is that!
There has to be a leak some where but its not getting to the ground. I'll have to take it in Mon. to have them look into it. Question I have is there any know issues with losing coolant?
Old 05-19-2007, 10:42 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
The one that gets the most attention is the water pump. Check around the shaft.
Ray
Old 05-19-2007, 10:49 PM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
No bulletins on the 07...I'd suggest that you tell the dealer that you topped off the system 1X already, but don't top it off again before you bring it to the dealer...this way they will see that the reservoir is empty
-Mike
AKA PROVY
Rock On!
Old 05-20-2007, 06:59 AM
ZsTB's Avatar
ZsTB ZsTB is offline
2004 Chevy TrailBlazer LTZ
Summit White w/Silver 4.2L I6 4X4
Do a quick check on the passenger side floorboard to make sure your heater core is not at fault, or has a loose hose. Being an 07, you would hope not, but never know.
Old 05-20-2007, 08:58 AM
bust_ter's Avatar
bust_ter bust_ter is offline
2003 Olds Bravada
White 4.2L I6 AWD
Not to worry you but it could be a small crack in the head leaking water to the combustion chamber.
Check your exaust for excessive water coming out.
Old 05-20-2007, 11:09 AM
I'll check it out.
I notice that I can smell it when I get out after driving. But like I said its not hitting the ground and I can't see any in the engine bay. At least its under warranty
Old 05-20-2007, 11:41 AM
The_Intimidator's Avatar
The_Intimidator The_Intimidator is offline
2002 GMC Envoy SLT XL
silver 4.2L I6 4X4
wow a 07 with a bad head/gasket hope it get's fixed up for you not nice to have problems so soon.
can you see white smoke out the exhaust or does it have a sweet smell to it?
Old 05-20-2007, 11:56 AM
Sweet smell from the engnie bay after I get out from driving.
Old 05-20-2007, 12:07 PM
silver 4.2L I6 4X4
hmm maybe you have a leak in one of the heater lines. It could be dripping onto the exhaust manifold and burning off before hitting the ground you need to get a pressure tester for the cooling system and look for leak's and to see if it will hold pressure. you could have a trusted local shop do this for you should only take them 15 minutes to determin the problem assuming it is a external leak one of the hoses rad water pump ect if it is internal you will be best to take it back to gm for diagnoses and repair
Old 05-20-2007, 02:54 PM
bust_ter's Avatar
2003 Olds Bravada
White 4.2L I6 AWD
smell
If the smell is from the front something like the water pump is a possibility.
It may be a small enoug leak that it burns it off and leaves little trace of leakage on the ground. Pump, Hose, thermostat housing, lots of things to look at.
Similar Threads
How many are having DEXCOOL Problems ? Fud OEM Issues 31 01-05-2008 08:23 PM
No GUNK from DEXCOOL rbarrios General 17 10-18-2007 07:36 PM
Dexcool and premixed antifreeze question rbarrios General 14 10-13-2007 12:06 AM
Dexcool garbage Spong OEM Issues 33 07-10-2006 06:39 PM
dexcool? Or other coolants? Fleet OEM Issues 4 05-25-2006 05:23 PM
