P0526/Cooling Fan Speed Sensor Circuit - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-20-2005, 01:02 AM
OurZoo's Avatar
OurZoo OurZoo is offline
Black & Stl Blue Metallic AWD
I pulled this code with my Interceptor gauge I installed today. Anyone every had this code before? Should I be rushing to the dealer or get in there when I can?
I found the following when I searched for this code:
Sensed Parameter:EV Cooling Fan Sensor Circuit
Fault Code:P0526
Monitor Strategy Description: Detects a continuous open or short condition with the EV Cooling Fan Sensor input circuit(s)
Malfunction Criteria and Threshold Value(s):No EV Fan Sensor Circuit input activity is detected (fan speed is < than 40 RPM)
Secondary Parameters and Enable Conditions:Engine is running/System voltage is > 8.5 volts
'07 Grand Cherokee SRT8 Diablo Tuned/Bwoody CAI/BORLA S Exhaust/Spacers/180 Tstat
'07 Charger SRT8Diablo Tuned/AFE II CAI/BORLA Exhaust/180 Tstat
Old 11-20-2005, 02:12 AM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
Fault Code:P0526
Cant help, but hey, the guage is already helping you out!!! And, you havent even driven very much yet!!! Woohoo!!
Old 11-20-2005, 09:59 AM
OurZoo's Avatar
I was thinking about the code. It might be an old code the computer hasn't even cleared yet?
Old 11-20-2005, 12:24 PM
bmm354's Avatar
bmm354 bmm354 is offline
2002 GMC Envoy SLT
Sandalwood Metallic 4.2L I6 4X4
Sounds like your fan clutch (what drives the engine cooling fan) has given up the ghost. This is a common problem with our trucks. I would recommend you get to the dealer "soon," esp. if you're going to be doing any towing or hauling. Plus it's probably warm enough where you are that you don't want to run the risk of having the engine run hot if you get stuck in traffic.
This code will set if the powertrain computer (PCM) loses input from the fan clutch. When this code sets the PCM commands the fan to 100% engagement, which means if your clutch was working electrically you'd hear a load roar every time you hit the gas. Your XUV would be much noisier than normal and you'd notice something was up. However if the clutch is dead, than the PCM can command all it wants but nothing will happen.
Have you seen the service engine light recently? Even if not there is still a problem. The light will only come on if the PCM detects the problem 2X in a row. It will go out after 3 consecutive trips with no problem detected, but the code is still stored.
Couple other things: Have you run the engine at all without the drive belt on? This will set the code. Has the clutch already been replaced and maybe the dealer forgot to clear the code?
If the dealer determines the clutch is bad make sure they install the updated part and perform the PCM flash to improve cooling and A/C performance. This is discussed in detail here:
http://forums.trailvoy.com/showthrea...ght=fan+clutch
2002 Envoy SLT, 116K
Sandalwood Metallic
Old 11-20-2005, 12:49 PM
APDMC6008's Avatar
APDMC6008 APDMC6008 is offline
2006 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
Check to make sure the electrical connector parts for the clutch is seated tightly...looking from the frt of the veh it's at the rt side of the fan shroud. The trouble code you describe almost sounds like the fan clutch isn't communicating with the PCM, so the PCM doesn't know the status of the fan. It could possibly even be indication only - the fan is responding but it's not sending any readings back to the computer, which would cause the PCM to assume it's not working properly. The first time my truck threw that code was when I was driving 70MPH on the interstate and the clutch went tango uniform and fully engaged to the fail-safe setting. I thought the fan was going to shell out at that speed . It later reset. The code may clear if it was intermittent, if it gets a signal back it might just go away. If it IS your fan clutch, you can change it yourself if your truck is not under warranty, but expect some time to be involved if you can't get your hands on the fan clutch tool. But it still saves you over $300!!!!
In memory of PFC Dawn Tillman, County 138
Old 11-21-2005, 01:09 AM
OurZoo's Avatar
While I was on the freeway tonight on the way home from work, I checked for codes just see if the code would be there. It was not.....When I got home, pulled in the garage and rechecked. Sure enough, the code was there!
I'll start with checking under the hood. I've unplugged that bad boy recently when I installed my last Westers tune. I know I plugged it back in for sure, but maybe it just isn't seated correctly. Then, if need be off to the dealer. I'm still under warranty, so its just some of my time. If they flash the pcm though, they will overwrite my tune.
Old 11-21-2005, 10:02 AM
APDMC6008's Avatar
Yeah, mine would throw a code and put on the SES light. Then it would go out. Then maybe months would go by and it'd come on again, and then go out either on the same trip within minutes, or it'd stay on for a few trips. All the while my fan was up to it's old tricks. Start truck up...fully engaged, and it would stay that way until I got up to about 40-50 MPH and I think it just reached its max RPM and would slowly fade back to normal. But slow down for any amount of time (ATM/fast food drive-thru, traffic, slow driving in subdivisions, etc) and it would be ramping back up to fully engaged. As luck would have it, when I brought it to the dealer very early on in it's failure the thing performed flawlessly, and worked just fine for about 3 weeks, and then it went back and stayed there. I wonder how much my gas mileage plummeted when the fan was f*d up. I don't really keep track of my mileage. I have a general idea that it's in the upper teens, so I notice if it gets substantially worse, but I'm not one of those people that takes the time to keep records so I can record a .2 mpg increase. Not worth the effort. Anyways, hopefully they won't need to reflash it so you don't lose the tune.
Old 11-21-2005, 11:13 PM
OurZoo's Avatar
Gas mileage difference, huh? How does that correlate? Funny you say that cuz I noticed this last fill up that my mileage went in the crapper.
Old 11-21-2005, 11:49 PM
Northwest Chapter
not here Other AWD
Fan clutch locked on= bad mileage.
Sorry Andrew, think it is time to get it replaced.
Old 11-22-2005, 12:01 AM
OurZoo's Avatar
Good to know the gauge works at least. I'm sure my service advisor will get a kick out of how I know what's up with the truck. Gonna have to be next week that I take it in though b/c of the holiday and all. I guess that means I'm gonna suck down another tank of petro real quick!
Similar Threads
Fan clutch 101 GMT 360 OEM Issues 366 12-01-2015 10:26 AM
service bulletin# 060602003 bcslvrss OEM Issues 11 05-28-2009 07:17 PM
Fan Clutch 4.2 Question markhart1 OEM Issues 9 12-01-2008 08:10 PM
P0-495 - Fan Speed High - Fan Clutch? Landis OEM Issues 5 12-20-2007 02:29 PM
Single/Double fan speed control? YOU Decide! alvin@pcmofnc PCM of NC 5 04-25-2007 11:21 PM
