Engine coolant change - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain
02-09 Vortec 4.2L I-6 Engine and Drivetrain Q&A forum for engine and drivetrain repairs/modifications/tuning.
Old 06-08-2007, 10:27 PM
DaveH DaveH is offline
2002 Chevy TrailBlazer LT
Pewter Metallic 4.2L I6 4X4
At what miles or time interval do most of you change your engine coolant. Owners manual says it is good for 150,000 miles. That seems an awful long time. My TB has 72,000 miles and was six years old on May 26, 2007. Should I change it? Any thoughts?
Dave
Quick reply to this message
Old 06-08-2007, 10:35 PM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
I would do it because of the age. Ill be doing mine next year (will be 5 yrs old) and I shouldn't have more then 50K on it by then.my
150K does sound reaaaaaaly long
Old 06-09-2007, 01:45 AM
ehall0527's Avatar
ehall0527 ehall0527 is offline
Senior Member
I'd say change it now. Better safe than sorry. It's pretty easy to do yourself and the materials don't cost too much. It's really easy since the 2002's have a drain cock in the bottom of the radiator.
Old 06-09-2007, 02:53 AM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
My 02 was built 11/3/01, so it is time for a coolant change now, but I plan on doing it when I get back from my trip this coming week (Orlando and then to the Bahamas ) along with a set of brakes.
Old 06-09-2007, 03:28 PM
ssilicon ssilicon is offline
Senior Member
2007 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
Assuming a properly maintained Dexcool system... I would change it at least every 5 years. If you go higher than the 150 miles do it sooner (not likely). The chemistry starts to change in the fluid and not for the better. So freshening it up after 5 years is important.
As far as "properly maintained", do not let air get into the system any more than you can help. Regularily check the coolant color consistency etc. Keep it leak free and good hoses and pressure cap etc.
Old 06-11-2007, 10:04 PM
Sparty's Avatar
Sparty Sparty is offline
2002 Chevy TrailBlazer LS
Z71 . Onyx Black 4.2L I6 4X4
I changed mine after five years with just under 50K, it doesn't cost that much, better save than sorry.
Buy about five gallons of distilled water,
1. drain radiator,
2. top off with distilled water
3. warm up engine
4. let engine cool
start over at step one until radiator drains clear.
Buy two gallons of FULL strenght anti-freeze, drain water from radiator and refill with anti-freeze. Warm up engine, let cool and check for 50/50 strenght. If strenght is too low drain radiator some and add more full strenght A.F.
Old 06-11-2007, 10:09 PM
ehall0527's Avatar
Senior Member
Anti-freeze?? Dex-cool is what the Trailvoy's use and the two cannot be mixed. I don't think I would recommend the change. Just my
Old 06-12-2007, 10:25 PM
Sparty's Avatar
Anti-freeze can be any type.....
Old 06-12-2007, 10:42 PM
ehall0527's Avatar
Senior Member
Thanks for the clarification
Old 06-12-2007, 11:38 PM
Dave's Avatar
Dave Dave is offline
2006 GMC Envoy Denali
Red Jewel Tintcoat 5.3L V8 4X4
I would change it around 5 years or 100k. It wouldn't hurt to replace the serpetine belt, water pump, thermostat and hoses then also.
2009 GMC Yukon XL Denali AWD (replaced 06 Envoy Denali)
2007 Chevy Impala SS, 5.3 (replaced Totaled 03 TB EXT)
2008 Chevy Corvette 4LT (my toy)
You may not post new threads
You may not post replies
Similar Threads
Engine reduced power light flash78738 General 10 06-04-2009 11:52 AM
oil change DzSoLow Everything Off-Topic 4 03-15-2007 02:00 AM
Big guns have arrived! - Redux VTODD Engine Tunes/Mods 77 11-07-2006 03:13 PM
Overheating Help PLEASE ...the saga continues bbradyc5 OEM Issues 10 09-17-2006 12:32 PM
Change Engine Oil Light WTF?! MajesticLT03 General 9 08-18-2006 06:19 PM
