High Speed on Fan not working - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-06-2007, 12:39 PM
john_danielson john_danielson is offline
2006 Chevy TrailBlazer LS EXT
Yesterday in the 108 degree Norcal heat, my high speed (#5) on the fan quit working. Speeds 1-4 are working fine. Do you think it could be a fuse or is there a separate blower/fan for the high speed? I have a 2006 LS TB.
Old 07-06-2007, 12:47 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Probably #35 the blower fuse in the underhood fuse block. The blower motor gets power from that fuse only in the high "5" position.
Old 07-06-2007, 12:56 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
on a road trip- my #5 stopped working so I said to myself- when I get home Ill research it on trailvoy..... Later on I happened to turn it to #5 and it started blowing again.
I did nothing to it.
Old 07-06-2007, 01:18 PM
tblazed's Avatar
I remember someone traced that problem to bad solder connections in the resistor ass'y at the relay that supplies full power to the blower. That could explain your intermittent loss of high speed 5.
Old 07-06-2007, 01:20 PM
blktbz's Avatar
blktbz blktbz is offline
TrailVoy Guru
Onyx Black 4.2L I6 4X4
I had this problem once before. It actually remedied itself, as one day it started working again by itself.
Ex-TrailVoy'er, Current S10'er.
Old 07-06-2007, 02:09 PM
the roadie's Avatar
Originally Posted by tblazed View Post
...resistor ass'y at the relay that supplies full power to the blower...
If you have the electronic digital climate control, the fan speed is controlled by an electronic PWM (pulse width modulation) buffer mounted to the side of the fan housing. The resistor ass'y only exists on trucks with the manual climate control. John, what version do you have?
Old 07-06-2007, 02:26 PM
I have the manual control. When I get out of work today, I will start with the fuse and the solder connections as I have have intermittent problems. Thanks for the replies.
Old 07-06-2007, 05:45 PM
rbarrios's Avatar
TrailVoy Guru
in 106,000 miles- my number 5 stopped working for maybe 20 miles?... then it came back to life.
Maybe it was a solder connection? I dont know- I just know it works now.
Maybe one of those bumpy mexican roads jarred it into operation again?
Old 07-06-2007, 09:01 PM
MCOMEAU334's Avatar
MCOMEAU334 MCOMEAU334 is offline
Pewter Metallic 4.2L I6 4X4
My fan speed 1 wasn't working, Blower motor resistor was the problem. Simple fix. It's behind the glove box and it's about $18.00 for the part.
Old 07-06-2007, 09:38 PM
ehall0527's Avatar
ehall0527 ehall0527 is offline
Senior Member
2002 Chevy TrailBlazer LT
Do you have to solder the new resistor in place or does is just "come off"? I'm about to replace mine since my 1 & 2 fan speeds don't work
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Similar Threads
How to replace fan clutch? mattbuff5 OEM Issues 178 04-29-2016 01:46 AM
My Cholesterol is borderline high rbarrios Everything Off-Topic 15 04-28-2009 12:13 AM
fan (blower) motor not working... classone OEM Issues 0 07-21-2006 11:42 AM
Help W/ Dumb Fan Clutch LOWRIT00 OEM Issues 6 06-21-2006 11:12 PM
Help with a P1484 GhettoBlazer 02-09 Vortec 4.2L I-6 Engine and Drivetrain 10 06-09-2005 11:19 PM
