Need to replace my seatbelt...? on how to - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 07-24-2007, 02:31 AM
blu ya's Avatar
blu ya blu ya is offline
Senior Member
2003 Chevy TrailBlazer LS
The other day I decided not to drive, but be a passenger and sit in the back seat behind the driver. I pulled out the seat belt and discovered that the belt was frayed and pulling apart . Now this sucks cause of all the belts that gets used, this one has maybe been used less a dozen times. So I basically need to replace this one and I'm wondering what is involved to replace this. Also if anyone has a part # for this I would be very greatful for this.
Tim
Old 07-24-2007, 02:48 AM
KNBlazer's Avatar
KNBlazer KNBlazer is offline
Senior Member
2004 Chevy TrailBlazer LS EXT
Steel Gray Metallic 4.2L I6 2WD
Tim
well I would have to say blindly that it would be as easy as doing a brake job on the TB or even changing a flat... depending on which end you will have to pull the side panel off ... they will just snap off... I don't even think you need to completely remove it.. .. but like I said I am saying this blindly...
Old 07-24-2007, 07:03 AM
07TB 07TB is offline
2007 Chevy TrailBlazer LS
Rear Seat Belt Replacement (TrailBlazer, Envoy, Bravada)
Removal Procedure
Remove the rear seat belt upper guide shoulder bolt.
Remove the rear quarter upper trim, left or right side.
Remove the lower seat belt anchor bolt cover.
Remove the rear seat belt floor anchor bolt.
Remove the rear quarter lower trim, left or right side.
Remove the bolt that retains the rear seat belt retractor assembly to the body.
Remove the rear seat belt retractor assembly from the vehicle.
Installation Procedure
Position the rear seat belt retractor assembly to the vehicle.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the bolts which retain the rear seat belt retractor assembly to the body.
Tighten the rear seat belt retractor bolts to 70 Nm (52 lb ft).
Install the rear quarter lower trim, left or right side.
Install the rear seat belt floor anchor bolt. Ensure that the seat belt webbing is not twisted.
Tighten the rear seat belt floor anchor bolt to 70 Nm (52 lb ft).
Install the anchor bolt cover.
Install the rear quarter upper trim, left or right side.
Install the rear seat belt upper guide with the bolt. Ensure that the seat belt webbing is not twisted.
Tighten the rear seat belt upper guide bolt to 70 Nm (52 lb ft).
Old 07-24-2007, 07:29 AM
jimmyjam's Avatar
jimmyjam jimmyjam is offline
TrailVoy Guru
2006 Chevy TrailBlazer SS (LT)
White 402ci Other AWD
you'll need a torx-50 socket. not much to it, just 2 t50 bolts. just have to remove paneling
Old 07-24-2007, 05:19 PM
jsdomino's Avatar
jsdomino jsdomino is offline
2002 Chevy TrailBlazer LT
Majestic Red Metallic 4.2L I6 AWD
Call your dealer. Seat belts should be covered for the life of the car.
Similar Threads
2002 Tb RPO Codes VITb General 12 07-09-2009 01:06 PM
Fat Guys and Tall guys seatbelt issues Chickengas Interior 22 06-06-2009 09:32 AM
2002 Trailblazer LTZ ... need instructions on replacing mode door actuator sw2001 OEM Issues 4 02-05-2008 08:45 AM
seatbelt chimes?i know i know schultzy007 Interior 8 09-27-2007 12:12 PM
