Oil Life Change Indicator - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain
02-09 Vortec 4.2L I-6 Engine and Drivetrain Q&A forum for engine and drivetrain repairs/modifications/tuning.
Old 08-04-2007, 12:45 AM
CDubb1977 CDubb1977 is offline
2003 Chevy TrailBlazer LT
Pewter Metallic 4.2L I6 4X4
Got a problem and need some help!!! Shame on me but I've been neglecting my baby (TB) and was a couple of months overdue on my oil change, my Oil Life indicator was showing 23%. So I go through the whole Jiffy Lube ordeal and get a oil change but after, noticed my Oil Life indicator is still at 23%. Normally it increases to 100% after the oil change, whats the problem? Need advice....thanks!!!
Quick reply to this message
Old 08-04-2007, 12:51 AM
06voy 06voy is offline
2006 GMC Envoy SLE
Liquid Silver Metallic 4.2L I6 2WD
just needs to be reset. Think you go to the oil gauge and hold enter.
Old 08-04-2007, 12:55 AM
PANGGOY's Avatar
PANGGOY PANGGOY is offline
2006 Chevy TrailBlazer LS
Silver Blue Metallic 4.2L I6 2WD
same thing happened to me. if you dont have DIC you can manually reset it. this is what i did.
just turn the key to on position(not start) then step on the gas pedal 3x. turn to off then when you start it its back to 100%.
Once you go Glock, you don't go back...
Old 08-04-2007, 12:57 AM
KNBlazer's Avatar
KNBlazer KNBlazer is offline
Senior Member
2004 Chevy TrailBlazer LS EXT
Steel Gray Metallic 4.2L I6 2WD
in addition to the above mentioned steps ...when you hit the pedal 3 X it needs to be inside a span of 5 seconds and you must let the oil light flash and stop flashing before turning the key to off then after that you can fire it up and should be reset...
Old 08-06-2007, 04:33 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
if you were at 23% and had your oil changed- I dont consider that oil change overdue. Oil still had life left in it.
If you had the oil changed in the last 300-500 miles or so- simply reset it and forget about it. and if you want change the oil next time the oil light comes on.
but all is fine if it was at 23%
You may not post new threads
You may not post replies
Similar Threads
Change Engine Oil Light Not very Reliable jigubhai2001 General 25 09-23-2011 04:15 PM
first oil change rjgnwdc General 19 07-09-2007 05:05 PM
Oil Change Frequency EnvoyCruzer 02-09 Vortec 4.2L I-6 Engine and Drivetrain 31 08-30-2006 10:15 AM
Oil change @... TuBlaz 02-09 Vortec 4.2L I-6 Engine and Drivetrain 23 07-12-2006 10:20 AM
Help w/ Oil Change kaboom 02-09 Vortec 4.2L I-6 Engine and Drivetrain 36 06-28-2006 01:35 PM
