| OEM Issues Original Equipment Repairs/Problems |
08-06-2007, 12:18 AM
Senior Member
2006 Chevy TrailBlazer SS Black 6.0L LS2 V8 AWD
Battery Guage
Ok so Im driving home just now from long Island (from video taping the worst wedding ever!!) and noticed something strange...about every few minutes or so my battery guage would drop down 4 notches very quickly then climb back up. When it dipped the cluster would dim then brighten back up. the truck didnt stutter or stall or lose power mechanically at all so im wondering what that was...never happened before unless I didn notice it but Im pretty good with that little stuff...my eye went right to it...any suggestions?? I am almost at 32,000 miles in only a year and 4 months...alternator? battery?
12.49 @ 107.05....Tune Time Performance...thats all I have to say...
08-06-2007, 12:43 AM
2006 GMC Envoy SLE Liquid Silver Metallic 4.2L I6 2WD
might be the alternator.
08-06-2007, 09:27 AM
'02 ORIGINAL TV GMC Envoy SLT ITS BLACK @ BAD 4.2L I6 4X4
Well Check Battery Terminals May Be A Lil Dirty.....kinda Sounds Like An Alternator Problem...which Im Sure U Allready Did That ...good Luck
08-06-2007, 11:54 AM
2003 GMC Envoy SLT Pewter Metallic 4.2L I6 2WD
You're still under warranty. Let the Dealer worry about it. It's most likely the alternator or voltage regulator (which is integral to the alternator).
08-06-2007, 12:15 PM
2005 Chevy TrailBlazer LS Dark Gray Metallic 4.2L I6 4X4
i have been having the same problem, replaced the alternator, checked things and still havent fixed it. its jst an annoyance as far as i see.
08-06-2007, 01:49 PM
2006 Chevy TrailBlazer SS Superior Blue Metallic 6.0L LS2 V8 AWD
Just out of curiosity, how much do your underdrive pulley(s) slow down your alternator? Amp output from the alternator drops relative to rpm, although it climbs quickly to the rated amp output from idle. If the alternator is running too slow and the amp demand is higher than the output, it will draw from the battery at that point. I'm just wondering if the pulleys are creating a situation where the battery is being worked more than normal and if the dealer may not honor the warranty on the charging system. Anyone with some more knowledge on the charging system and operation want to chime in? I'm just curious if it might be related to some long term effect of the pulleys.
08-06-2007, 02:08 PM
Senior Member
yeah I was curious if the UD pulleys were helping cause this problem..its not really a big deal but its a little annoying...ill throw a volt metter on this weekend to see how low its really going...
08-06-2007, 02:22 PM
2007 Chevy TrailBlazer SS Black 6.0L LS2 V8 2WD
http://www.gmperformancetuning.com/f...ead.php?t=6902
Here is a little bit of info on how the system works.
08-06-2007, 02:35 PM
Senior Member
yeah i was just reading up on that but thats in the 07's...not the 06's and def not in the trailblazers I dont believe...
08-06-2007, 02:44 PM
My 07' TBSS owner's manual has something about how the charging system works. Sounds about the same as posted.
You may not post new threads
You may not post replies
