Wiring diagram for bose system - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-10-2007, 12:42 PM
maintainin76 maintainin76 is offline
2007 Chevy TrailBlazer SS
Summit White 6.0L LS2 V8 AWD
Anybody know where I can find a wiring diagram for the bose system? More specifically I need to know the speaker wire colors of the rear speakers because I want to add a line output converter so I can run my amp and sub. Is there an amlifier mounted somewhere for the bose system?
Old 08-11-2007, 10:33 PM
Just FYI, I found the bose amplifier. It's behind the plastic panel in the right rear of the truck. Also, if anybody ever wants to put a line output converter for a sub you are going to need to patch into the FRONT door speakers and not the rear. The wire colors coming out of the amp for the front are tan/gray and green/light green. I spliced into the ones in the rear first but there isnt enough signal(must be only putting out mid and high) and even with turning the gain all the way up on my amp it still was only putting out half of what it should. The front speakers provide the lows and are what you want to splice the converter into for a sub.
Old 08-13-2007, 09:39 PM
Venomblue22 Venomblue22 is offline
Black W/ Custom Paint Job 6.0L LS2 V8 AWD
You dont by chance know if there is any aux ibputs on the back of the navi do ya. I.e. for a cd changer, ipod, hard drive etc?
Old 12-24-2008, 02:17 AM
arturoeavila arturoeavila is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
no there is no aux input . but you could purchase an isimple ipod box and harness and it will work thru your xm stations .. works great
Old 03-16-2010, 07:33 PM
getsumss's Avatar
getsumss getsumss is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
is the amp underneath the whole side panel or can i just hook the line input converter in the back of the head unit using the same tan/grey and green/light green wires.? Thanks for the help i have an 06 tbss with bose
Old 11-21-2013, 04:52 PM
Povozmojno Povozmojno is offline
qwerty qwerty qwerty
qwerty 5.3L V8 4X4
Thank you for*good*communication.
Old 03-06-2014, 06:36 PM
RBD94 RBD94 is offline
Lurking Newbie
AMP bypass
On a little different note, if you put in a new head unit as a way to connect with an iPhone, would that bypass the amp? I ask because I put one in and I seem to lose a lot of the "power". I used a standard wiring harness converter and I'm not sure if I may have missed something.
Similar Threads
wiring diagram for amp to 2002 tb bose stereo upgrade rclark7 Audio and Electronics 11 06-26-2010 01:25 AM
Need pinouts or wiring diagram for stock radio 08 TB LS Boring Audio and Electronics 0 02-07-2008 09:17 AM
Wiring diagram rsincav General 5 05-27-2006 08:51 AM
New Member looking for info on stock headunit harness wiring diagram amsgwp Audio and Electronics 3 04-27-2006 11:38 AM
wiring diagram jscholl411 Audio and Electronics 2 06-24-2005 06:48 PM
