Reduced Engine Power Sensor - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 08-12-2007, 03:00 PM
Gerry Waddell Gerry Waddell is offline
New Member
2003 Chevy TrailBlazer LS EXT
Summit White 5.3L V8 2WD
The reduced engine power sensor on my 2003 Trailblazer keeps activating.
I have had it in the shop 5 times. Dealer has installed software updates, but
problem persists and is getting worse. They have no idea what is causing
this. Factory support has been no help. Looking for solutions.
Old 08-12-2007, 03:26 PM
rcam81 rcam81 is offline
2007 Chevy TrailBlazer LS
Welcome to the group. Something that you could do to help us diagnose your problem is to fill in your profile. Once you do that, the info will start flying.
Old 08-12-2007, 10:20 PM
blandmiller's Avatar
blandmiller blandmiller is offline
2002 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Welcome to the site.
The "reduced engine power" message is not a sensor. It is a message from the PCM that some sensor(s) or operating parameters are not reporting correct information to the PCM or the sensor(s) are providing information that is causing the PCM to protect the powertrain. The problems that can cause a reduced engine power are probably too numerous to list.
Next time it happens, make sure you get the DTC codes and post them to the site. You should get many responses once you have some codes that everyone can make sense of. There are several very helpful members that can start to diagnose the problem with a little additional information.
I also agree with rcam81, fill out your profile so we all know what configuration you are driving.
Ed Bland '02 TB LT 4.2L I6 4x4 Onyx Black
"The Chassis Dyno Doesn't LIE!!!!:
Old 08-12-2007, 11:08 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
A friend of mine had his accelerator pedal sender-resistor gizmo fail and got the reduced power light. Replaced the pedal ass'y and that fixed it. I think it set a code so you might get that checked somewhere like AutoZone who will do it free. A stored code should lead you in the right direction.
Old 08-25-2007, 01:28 AM
Towpig Towpig is offline
2006 Chevy TrailBlazer LT
Black 5.3L V8 2WD
My wife had this happen on the 06 5.3L and it turned out to be the throttle body and the ignition switch. Truck wouldn't go over 30MPH and the reduced engine power light was on. It definitely didnt protect the motor because right now it's in for a new long block.
2007 SSilverSStone 2wd
2002 Silverado 3500 4dr Duramax/Allison
1994 S10 355/TH400/3.73 Procharged & Fogged
Old 08-26-2007, 04:32 PM
Nukedog's Avatar
Nukedog Nukedog is offline
Senior Member
2006 Chevy TrailBlazer LS
Graphite Metallic 5.3L V8 2WD
Apples and Oranges...
02 Busa 1397cc
05 ZX10R
08 Tundra DCRB 5.7
Old 08-30-2007, 06:22 PM
Black 5.3L V8 2WD
Be it the pedal or the throttle body, it is about the same. The sender or the receiver, the signal did not reach it's destination. But, I do know the computer does not shut down engine power due to signal input. It only tells you the drivetrain is not functioning properly. +/- 7-10% expectancy.
How much money would GM make if they shut down an engine due to heat or oil pressure, or had the DIC tell you exactly which sensor or part went bad?
Old 09-04-2007, 08:58 PM
accplu accplu is offline
New Member
2005 Chevy TrailBlazer LT EXT
Reduced Power, engine light on
Just bought 2005 GM Buy Back loaded EXT with 25k on it. Immediately after brake controller was installed under dash, the reduced power thing happened with a check engine light on. Dealer found wiring harness under dash problem and fixed it.
Old 03-20-2010, 04:52 PM
sarge355 sarge355 is offline
2003 Chevy TrailBlazer LTZ
Liquid Silver Metallic 5.3L V8 4X4
I am looking for some assistance. My 2003 Trailblazer has 63,000 miles and has been experiencing the reduced engine power problem. A GM dealer has replaced a fuel sensor, entire wiring harness, computer, and it still is occurring. The only other thing they plan to try is the accelerator assembly.
Any thoughts on whether or not this should fix the problem??? I've been a very loyal GM owner, but this experience has me reconsidering that...
Old 03-20-2010, 05:43 PM
the roadie's Avatar
On whose dime are they doing that INSANE and EXCESSIVE amount of guessing?
What exact code shows up in the computer when it goes into REP mode and sets the SES light?
Typically the code will point to the throttle body or the accelerator pedal. There's a TSB that it might also be chafing in the wiring harness from the PCM to the fan clutch, or a failure in the fan clutch. We're very familiar with it here on trailvoy - hard to believe the dealer isn't.
You may not post new threads
You may not post replies
Similar Threads
Check Engine and Reduced Power light? Trefilov22 OEM Issues 11 06-01-2012 08:48 PM
SES and Reduced Engine Power light on WayFastWhite OEM Issues 42 02-16-2011 09:58 PM
Anyone in Philadelphia Area able to change actual mileage? TrailinAlong517 TrailBlazer / Envoy Chat 10 11-13-2009 06:43 PM
reduced engine power mchase OEM Issues 4 02-02-2008 05:15 PM
Gen IV 5.3 LH6 Info... Windy City Engine Tunes/Mods 7 08-08-2006 10:41 AM
