Auto Climate Control Problem - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-13-2007, 09:49 AM
fbusse fbusse is offline
2005 Chevy TrailBlazer LT
Black 4.2L I6 4X4
My fiance and I went on a roadtrip up into the NC mountains over the weekend. The ac on the auto climate control system worked just fine. On the way home I went to turn on the AC system and only hot air came out. I looked in the backseat and the rear seat electronic controls would not work either. Besides being a little peeved that this happened on a new vehicle with just over 16k miles on it.... it was a long hot drive home.
Yesterday morning I hop in my TB only for all these functions to be working perfectly fine again.
Has this happened to anyone else or are there any recommendations of what I can tell the mechanic to look for when it goes in the shop. I wouldn't be happy if I took it in and the mechanic told me they could not duplicate the problem.
Old 08-13-2007, 10:55 AM
cbwilsha cbwilsha is offline
2003 GMC Envoy SLT
Pewter Metallic 4.2L I6 2WD
Most likely a defective Low Pressure Cycling Switch, a fairly common problem with these vehicles. It is covered under your warranty and takes only about 15 minutes to replace.
C.B.
Old 08-13-2007, 11:04 AM
jigubhai2001's Avatar
jigubhai2001 jigubhai2001 is offline
2004 Chevy TrailBlazer LS EXT
Summit White 4.2L I6 AWD
Its happened to me a couple times. but what i did is tuned engine off, removed the key and then restart again and everything worked fine. I dont know what caused it but like i said it has only happened a couple times.
Old 06-09-2008, 07:18 PM
BUC NASTY's Avatar
BUC NASTY BUC NASTY is offline
2002 Chevy BigBlazer SS Clone
Indigo Blue Metallic 4.2L I6 2WD
C.B.
is this a recall problem i can get done for free since my warrenty ran out? or do i have to pay it?
SS Conversion, SSBC Brake Kit, Avic D3, 22in Rims, Efans, 6000k Kits, SS Wiper Cowl, 35% Tint, Race Mesh Grills
Old 06-09-2008, 07:35 PM
2003 GMC Envoy SLT
It was never a recall but was a common problem. If your warranty is out and you don't have an extended warranty, You'll have to pay for it. I don't think it would be too expensive as the part is a really small one and it only takes about 15 minutes to change it.
C.B.
Old 06-10-2008, 03:12 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
if its the part I think it is... some people tap it with a screwdrivers head or similar and the AC comes to life!
Similar Threads
broke my climate control module, need part # gordinho80 Interior 3 03-21-2008 03:34 PM
Problems with Dual CLimate Control MWB_BigMike Interior 3 03-11-2008 02:00 PM
auto HVAC problem lekmedm Interior 3 07-02-2007 02:02 PM
03 tb ext climate control problem used car nut General 2 04-21-2007 09:56 PM
Climate control jesse13579 Interior 7 06-01-2006 04:10 PM
