A/C Blower Won't Turn Off?? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-14-2007, 10:02 PM
Trailblazer210 Trailblazer210 is offline
2006 Chevy TrailBlazer LT
Graystone Metallic 4.2L I6 2WD
Question A/C Blower Won't Turn Off??
When I turn off my car, the a/c blower keeps blowing at med-hi. I have the dual automatic a/c system. When the cars on, and you turn on the system, everything works but you can't control the speed of the blower. When you turn the system off or turn off the car, the blower stays on. Anyone ever have an issue like this? And can anyone help me?
Old 08-14-2007, 10:07 PM
KNBlazer's Avatar
KNBlazer KNBlazer is offline
Senior Member
2004 Chevy TrailBlazer LS EXT
Steel Gray Metallic 4.2L I6 2WD
yes I believe it is the blower resistor... try tapping it ... you will have to disconnect your battery if it doesn't shut off otherwise it will drain your battery... there was a user a few days ago that posted this same problem...
Old 08-14-2007, 10:43 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
The auto AC system doesn't have the resistor ass'y; it has a PWM motor driver module instead. Don't recall any of those being a problem though. Maybe a search would come up with something. Probably either that module or the controller that drives it. How do you get it to turn off now?
Old 08-19-2007, 12:16 PM
harleydude harleydude is offline
2004 Chevy TrailBlazer LT
Dark Green Metallic 4.2L I6 2WD
My wifes car is experiencing this problem as well. We first noticed a problem with the blower not even coming on, but with the vehicle in motion some cold air blew from the vents. Now the blower works somewhat but wont shut off when key in the off position. Removed the HVACB fuse from the backseat fuse block.
Thanks in advance
Rick
Old 08-19-2007, 12:36 PM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
Superior Blue Metallic 4.2L I6 4X4
A few things to consider from service information:
When the vehicle is moving, air flowing over the vehicle increases the air pressure just ahead of the windshield. This forces air into the outside air inlet, into the HVAC module and out through the floor and windshield outlets. Since the A/C compressor is not running, the incoming air may be warmed but not cooled.
This applies to vehicles built after February 5, 2006 and/or earlier vehicles that have had the HVAC control module updated (automatic air only):
The blower motor will turn on approximately 10 minutes after the vehicle is shut off. The blower motor will run continuously for 10 minutes at a 30% duty cycle. The afterblow function will only activate if the air conditioning compressor was engaged during conditions of high ambient temperature. If the vehicle is started within 10 minutes of the last key off, the afterblow function from the previous key cycle will be cancelled.
Hopefully this clears up some concerns; but Trailblazer210 may need the controller updated if unable to control the fan speed manually during operation
-Mike
AKA PROVY
Rock On!
Old 08-19-2007, 12:43 PM
Thanks for all the input guys! I took my car to the dealership yesterday and they said it was a resistor that had to be replaced. After a day of being at the dealership, the blower works great... for now. lol
Old 09-14-2014, 10:26 PM
Trailblazer2377 Trailblazer2377 is offline
Thumbs up Same issue with Blower speed
Replaced blower motor resistor and boom..... Works like new.... Holding my breath for a few days that it keeps working fine.... I read somewhere else that when someone replaced theirs it worked for a bit but malfunctioned again.... Pretty easy fix if you can contort your arms up underneath the glove box.... Great videos on youtube will help with DIY repairs...
thanks all!
Old 11-03-2014, 11:00 AM
08TBLT-MarionOH 08TBLT-MarionOH is offline
2008 Chevy TrailBlazer LT
Black 4.2L I6 4X4
Blower won't turn off
I have an '08 with the twin auto climate control system and mine started doing the same thing this morning.... the blower continues to run after the ignition is turned off. Also, in manual, I cannot vary the fan speed. Is my problem also the blower resistor? I also read above that the climate control systems do not have this resistor? Who has the correct story??
Thanks in advance!!
Old 05-28-2016, 07:41 PM
eashbaugh eashbaugh is offline
2002 Chevy TrailBlazer SS (LT)
white 4.2L I6 AWD
Not the resistor
I had the same problem with my 05 Trailblazer. I replaced the resistor pack and thought it had fixed the problem, but the OSA temp was cooler and the problem didn't exist, as soon as it went above 75 deg or so outside it started again. I think it has something to do with the OSA but can't find a good wiring schematic to really troubleshoot with.
Similar Threads
A/C blower fan won't run Cox89XJ General 10 07-08-2008 08:06 PM
A/C won't turn on at 1 slimfast OEM Issues 6 06-25-2008 12:31 PM
rear A/C blower issues, please help. davinci OEM Issues 7 07-28-2007 01:43 PM
A/C Blower Stays on with key off and loss of POWER. smoke OEM Issues 2 04-25-2007 04:21 PM
A/C Blower my-tb OEM Issues 18 09-03-2006 02:48 PM
