Engine whine... - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 12-06-2005, 10:42 PM
itchyfishnv's Avatar
itchyfishnv itchyfishnv is offline
Senior Member
2003 Chevy TrailBlazer LTZ
Black/Pewter 2 Tone 4.2L I6 4X4
Engine whine...
Anyone have a problem with their TB whining? My engine makes a whining noise. its not the tranny b/c it does it in park and neutral. Anyone have any idea? It almost sounds like a honda going in reverse.
Old 12-07-2005, 01:53 AM
APDMC6008's Avatar
APDMC6008 APDMC6008 is offline
2006 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
I think the worst part of that is it could sound like a Honda in any form or fashion
In memory of PFC Dawn Tillman, County 138
Old 12-07-2005, 01:57 AM
Jman423's Avatar
Jman423 Jman423 is offline
Red Jewel Tintcoat 6.0L LS2 V8 2WD
I was thinking the same thing!!
Old 12-07-2005, 07:37 AM
Senior Member
No i mean its not THAT bad, its just that my other 02 TB never did it. I was wondering if theres something up with it.
Old 12-07-2005, 09:01 AM
05trail's Avatar
05trail 05trail is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
I think we might need some more information to help you out. Did you do anything to your Trailblazer before you started hearing this noise? When does it happen? Stuff like that.
2005 Trailblazer LS 4x4
Old 12-07-2005, 10:03 AM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Take the drive belt off temporarily and run it to check for one of the accessories making the noise, like the alternator, power steering pump, idler pulley etc.
You musta forgot to "test listen" to it first before you bought it!
Old 12-07-2005, 11:37 AM
Senior Member
I only hear it when its cold, once it starts to run and warm up the sound goes away.. i dunno.
Old 12-07-2005, 11:52 AM
ylab's Avatar
ylab ylab is offline
2002 GMC Envoy SLT
I think Tblazed is most likely right on and its something on the accessory drive making the noise.
What year is your TB?....They begain using an AIR pump when they went to the larger CAT in 2004 or 2005 and every vehicle I've owned with one made some noise when cold.
Old 04-13-2006, 05:52 PM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
Bump...I've been having the same problem. The whine follows the engine revs, sorta sounds like a supercharger but it's really annoying. What belt do i remove to check?
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
THESE BIG RED LETTERS HELP ME FIND MY POST
Old 04-13-2006, 06:46 PM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
You could release the tension on the serpentine belt tensioner by pushing it down (see pic below) Pop the belt off & give every pulley a spin that will spin by hand. The 'normal' wear items here would be the tensioner pulley and the idler pulley (under the alternator). This could also be a bad bearing in the waterpump, alternator, P-steering pump or a/c compressor.
G/luck
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Similar Threads
Finally fixed my engine whine! Audiojunky OEM Issues 240 11-07-2016 11:07 AM
Remove alternator to change Thermostat? mastermonkhabib Engine Tunes/Mods 141 03-24-2015 07:21 AM
Engine Whine at WOT BLK06TBSS OEM Issues 4 11-08-2006 11:25 PM
Gen IV 5.3 LH6 Info... Windy City Engine Tunes/Mods 7 08-08-2006 10:41 AM
05 TB DOD status? muddy tires 02-09 Vortec 4.2L I-6 Engine and Drivetrain 19 07-28-2006 10:00 PM
