A/C won't blow out of front vents - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-10-2007, 04:29 PM
inCREDEble inCREDEble is offline
New Member
2004 GMC Envoy SLT
Onyx Black 4.2L I6 4X4
My 04 Envoy's A/C won't blow out of the front main vents.
The A/C is fully digital so all I do is push the mode button. The A/C does work on defrost and on the feet, it just wont blow out of the front vents.
The second row's A/C work just fine.
Any ideas?
Old 09-10-2007, 05:05 PM
pvgoheelsunc1 pvgoheelsunc1 is offline
2003 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
Look on this site below and see thread called "Lemon law" and "2002 Climate Control". Has info about your problem. You probably have a bad door control unit located behind the AC control switch....also see thread on engine and drive train called "AC problem" by rattletrap....
Old 09-10-2007, 05:43 PM
New Member
2004 GMC Envoy SLT
Which site?
Or are you telling me to search here?
Old 09-10-2007, 06:12 PM
85vette's Avatar
85vette 85vette is offline
TrailVoy Guru
2004 Cadillac TrailBlazer LT
Majestic Red/Sandstone 4.2L I6 2WD
Mine went to the dealer for that today. It would half blow out the defrost at times. They called me back and said they couldn't duplicate the problem. How did I know that?! They said they could try to reprogram it for $85.00. I told them I would wait till it quit working altogether and let my extended warranty cover it.
Old 09-10-2007, 06:26 PM
click here..... http://forums.trailvoy.com/showthread.php?t=29567
Old 09-10-2007, 06:47 PM
AndrewB's Avatar
AndrewB AndrewB is offline
2002 Chevy TrailBlazer LTZ
I have a friend that works at a Chevrolet dealer and he said the blend doors are a nightmare!
Old 09-11-2007, 12:07 AM
xenolith xenolith is offline
2006 Chevy TrailBlazer LS
Sigh, mine is sitting at dealer now for the same issue. I have the manual climate control system. Like many others reported in other posts, the problem started after dead-cell battery replacement.
Old 09-11-2007, 09:39 AM
AbsoluteZero AbsoluteZero is offline
2003 GMC Envoy SLT
Any ideas?
I had this problem w/03 Envoy. See my post in this thread:
http://forums.trailvoy.com/showthread.php?t=23002
Old 09-11-2007, 11:58 AM
New Member
2004 GMC Envoy SLT
Thanks for all the replies!
Old 09-14-2007, 08:26 PM
wookiee2cu wookiee2cu is offline
I had a similar problem. I would have the fan on full blast and the driver's side middle vent hardly pushed out any air. I took it into the dealership (my buddy is a service writer there), I got a call a few hours later and he said it was the temperature door module (or something like that). It was going to cost about $500 to fix but he got me the employee rate and got it down to about $419 after tax. The part was about $130 the rest was labor as they have to rip out the entire dash and remove some of the hardware in the center of the dash to get to the part.
Similar Threads
Lowering Front End To Level? crusher72 Suspension 8 09-28-2007 12:04 AM
Front Struts Dead palitoiii Suspension 7 09-07-2007 06:49 PM
Rear A/C and Compressor KNBlazer OEM Issues 2 08-18-2007 07:31 PM
noise when a/c is on aw OEM Issues 5 07-09-2007 01:37 PM
4.2L Oil Leaks garymugs OEM Issues 16 07-21-2005 07:39 PM
