AC causes Envoy to Stall - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-16-2007, 01:35 AM
Mesee3 Mesee3 is offline
2002 GMC Envoy SLE
Dark Gray Metallic 4.2L I6 2WD
I recently replaced my battery. When I started my Envoy the first time with the new battery, a click-click-click (about 15 seconds) noise came from behind the AC controls and now the car imedieatly stalls when I turn on the HAC fan. Envoy runs fine without fan on?
Old 09-16-2007, 03:59 PM
markhart1's Avatar
markhart1 markhart1 is offline
2005 Chevy TrailBlazer LS
Hello,
Please update your profile so we know what year, engine etc... you have.
A couple things come to mind. Have you had the alternator checked to make sure it's working OK? Why did you have to replace the battery and if so, is it rated properly for the car?
Old 09-16-2007, 08:16 PM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
2006 Chevy TrailBlazer LT
Superior Blue Metallic 4.2L I6 4X4
Please fill out all of your vehicle information in your Profile so that we can keep you informed with the most useful information available
After you do that, follow the procedure outlined in this article for cleaning your throttle body, that should correct your stalling condition
http://forums.trailvoy.com/articles....ticle&artid=91
As for the A/C clicking...did it only happen the first re-start after the battery was replaced? If so, you were probably hearing the mode door actuators calibrating If you hear the clicking all of the time (from the dashboard), you may have a problem with one of your mode door actuators
-Mike
AKA PROVY
Rock On!
Old 09-17-2007, 07:03 PM
rubberman's Avatar
rubberman rubberman is offline
2004 Chevy TrailBlazer LS EXT
i have something similar on mine that i noticed today. either parked or at a light the engine RPMs will be normal then choke down to 300 rpms like its gonna die then jump back up to normal RPMs. it will continuously do this while the A?C is on. i guess this is service bulletin 04-01-38-019a. i will be taking mine in anyway since they said they would touch up some scratches. i have about a week left on warranty so i hope this covered.
2004 TB EXT I6 CAI, PCM4Less PCM, Resonator delete, Kuhmo KL51
Old 09-24-2007, 04:45 PM
2002 GMC Envoy SLE
Updated info
I updated my profile. 02 Envoy SLE 4.2L.
I replaced my battery, because I orginally lost all power to my rear tellgate. After closer examination, I found all the wires in the tellgate were cut at the hindge, I figured the cut wires were grounding out and killed my battery. It took me about 3 month to resolve the loss of rear tellgate power and the battery slowly drained over the three months until it was dead.
I reconnected the wires in the tellgate and replaced the battery and all was good until I turned on my AC Fan. Now Envoy stalls imedieatly.
Also, clicking sound only happend once, when the battery was connected, so It probably was a calibration thing. Thanks
Old 09-25-2007, 04:00 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
yeah, do the throttle body cleaning- let us know the result.
Old 09-25-2007, 07:23 PM
rubberman's Avatar
yeap, TB needs cleaned. i had mine done at the service department since mine was under warranty or i would of done this myself. Receipt shows 'excessive carbon buildup". maybe by cleaning this, i could get a touch of better MPGs
Old 09-26-2007, 02:25 PM
icase81 icase81 is offline
Charcoal Metallic 4.2L I6 4X4
Post
I was gonna say, I never had to do it with my TB, but on lots of my older VW's, car choking at idle with A/C on was 99% of the time a dirty throttle body. Clean it up and it should be good to go.
Old 09-27-2007, 12:10 AM
exttb exttb is offline
2003 Chevy TrailBlazer LT EXT
Dark Green Metallic 4.2L I6 2WD
or disconnect negative terminal and let the vehicle reset for 1 minute....my ac fan resisitor went out when I changed my battery
2003 TB LT EXT I6 213,000 miles pcmforless tune with efans..Volant cai ...no cat..no name muffler..EFI live 1.2...
Old 09-27-2007, 02:01 PM
carp's Avatar
carp carp is offline
Black 4.2L I6 2WD
I cleaned my TB as per the how-to instructions, but didn't disconect my battery prior to doing it. Noticed a slight improvement. Should I now disconect the battery for a while to get the full benefit? And if so, do you disconect BOTH terminals? For how long? Thanks
Similar Threads
OEM Trailblazer, Envoy Electronic Visco Fan Clutches EuroPartsAmeric Basic Vendor GroupBuys 26 01-14-2012 03:54 AM
fan clutch? webjoe98 OEM Issues 7 01-29-2008 06:43 AM
What would you get? ImARockStar TrailBlazer / Envoy Chat 9 03-03-2007 11:21 AM
Another New guy, just picked up my 06 Envoy XL Denali! =) SSL kirkg1 Introductions 6 08-02-2006 02:49 PM
R.I.P. Envoy XUV Envoy Fan Latest GM News 8 02-24-2005 11:19 PM
