Turn Signal Relay - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > OEM Issues
OEM Issues Original Equipment Repairs/Problems
Old 09-18-2007, 10:05 PM
cmnm505 cmnm505 is offline
New Member
Turn Signal Relay
I need some help here - the other day my turn signals and hazard lights quit working. I checked ALL of the fuses they are good. I was told by the dealer that it was the turn signal relay. I went and got it but now I can't find where it goes. I looked in the fuse box under the back seat - (not there!!) I looked under the hood fuse box (drivers side) Not there! I looked under instrument panel - Not there! Can somebody please tell me where it goes??? The Chevy parts dealer who sold it to me - did not know where it goes - but dang there is a part for it so it must go some where!!!!!
Old 09-20-2007, 03:10 AM
BLZR SS's Avatar
BLZR SS BLZR SS is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 2WD
Flasher Relay
It's under the dash near the steering column at the firewall if I remember right. I had to replace the stock unit with a solid state one after I installed LED parking/turn indications in the front.
I hope this helps.
Bruce
'06 Blk LT2 SS 2WD; CAI/VMS tune/eFans, HSRK; billet bowtie; rear overlay; LED turn/park lamps
Old 09-20-2007, 06:06 PM
wmolzon wmolzon is offline
TrailVoy Guru
2008 Chevy TrailBlazer SS
Red Jewel Tintcoat 6.0L LS2 V8 AWD
I hope this helps.
Bruce
where did you get the new flasher from?
Old 09-20-2007, 07:11 PM
Envoy Fan's Avatar
Envoy Fan Envoy Fan is offline
TrailVoy Guru
2005 GMC Envoy Denali
Summit White 5.3L V8 4X4
I hope this helps.
Bruce
Yes, yes, where did you get the new flasher from?
BILL
Old 09-25-2007, 09:39 PM
New Member
Flasher
I got it from the Chevy Dealer - who was very hard pressed to tell me where it goes. I have torn apart the underside of my dash looking around under there near the firewall and still cannot find it.
Old 09-26-2007, 02:56 AM
BLZR SS's Avatar
Flasher Location
OK, I will try to describe the flasher location. If you look under the dash to the left of the steering column and find the larger wire loom that passed through the firewall. Then look for the dark plastic piece that has 2 notches in it with 2 light gray tabs that slide into the darker piece. The flasher is mounted to the light gray (female connector that has the conductors going to it). Slide the tabs to the wider part of the slot and remove the connector and flasher down to where you can remove the flasher and install the new one. I will try to post a photo of the location if my description is not clear enough.
I hope this helps.
Bruce
Old 09-27-2007, 03:14 PM
vetman03 vetman03 is offline
2007 Chevy TrailBlazer SS
Imperial Blue Metallic 6.0L LS2 V8 AWD
relay
my 04 tb had a recall on the relay about a year ago before i got the ss.
mike marshall, cincinnati.
Old 09-27-2007, 03:18 PM
relay
My 04 tb had a recall on the flasher relay about a year ago before i got
the ss.
Old 11-07-2013, 08:29 AM
Bibikalare Bibikalare is offline
qwerty qwerty qwerty
qwerty 5.3L V8 4X4
A great*exchange of information.
Old 04-09-2016, 06:43 PM
mwman2 mwman2 is offline
2002 Chevy TrailBlazer LS
Sandalwood Metallic 4.2L I6 4X4
Just went through leftturn signal hyper flash caused by a bulb problem. The bulb looked good but the plastic was slightly melted by the base terminal. The circuit board also showed signs of high thermal temps where the bulb plugs into the socket. It was replaced about six months ago. The Temps on these bulbs seem to be running too high for the circuit board materials. I decided to go to leds in the tail lights for the turns and brake/running bulbs which required the purchase of a led compatible flasher module. I went to Auto Zone and looked up their part number lm486 for a 2007 trailblazer. They can also order lm487 which is a heavy duty towing flasher. This Norvita LM487 flasher makes a louder click handles led bulbs and is cheaper than the other stores and dealer, USA made $43.99. You have to tell them to search for and special order this flasher, they got it in one day. Hope this helps.
Similar Threads
Need wiring diagrams LeonPhelps Audio and Electronics 4 03-21-2009 04:31 PM
Right Turn Signal Messed Up OKC_BOI Audio and Electronics 6 05-11-2008 03:27 PM
Turn signal problem. wolfe99 General 12 05-05-2008 08:40 PM
Mirror Turn Signal Issue BrokEnvoy Exterior 9 03-21-2008 03:15 PM
Turn Signal Relay Location for '03 cmnm505 General 8 09-20-2007 06:15 PM
