03 Envoy stalls when A/C is turned on - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-15-2007, 03:58 PM
air4kxc air4kxc is offline
My 03 Envoy stalls when the A/C is turned on. Started happening after replacing the battery. I don't know if there is a connection but seems odd.
Old 10-15-2007, 04:36 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
yes. classic symptom. Most likely the battery was disconnected for more than 25 minutes.
it caused by the computer losing some learned parameters and the throttle body being dirty.
the result is the engine runs fine with no AC. turn on AC and it idles from normal to 300 up to 1000 back to 300 etc... many times it shuts off...
the solution is about $4 bottle of throttle body cleaner and about 1 hr of your time.
theres a HOW TO around here....
Old 10-15-2007, 04:42 PM
rbarrios's Avatar
TrailVoy Guru
heres the how to.....
http://forums.trailvoy.com/articles....ticle&artid=91
ive done this, except I didnt remove it. I simply sprayed and moved the flap to loosen crud. For a more thorough cleaning, follow article.
Old 10-16-2007, 07:10 AM
Thanks, It Worked! I removed the Throttle Body, cleaned it and it runs great. You guys are good.
Old 10-16-2007, 12:53 PM
rbarrios's Avatar
TrailVoy Guru
hey. thanks for letting us know so quickly that you got it back to normal
Old 07-12-2014, 02:18 PM
Robthemac Robthemac is offline
2002 Chevy TrailBlazer LT EXT
Black 4.2L I6 4X4
Obviously the best solution is to have a nice clean throttle body, but isn't there a way to have the computer relearn the old parameters?
Old 11-02-2014, 04:48 PM
RynoWorthy RynoWorthy is offline
2004 GMC Envoy SLT XUV
Black 4.2L I6 2WD
(AC and Heater causing my envoy to have bad idle and rpm spikes) 100% connected to throttle body! I cleaned it thoroughly and test drove it and was finally able to idle at a constant while testing both heater and AC. Thanks for your help! Much appreciated! Now I have what I think is an exhaust issue...😓 possible catalytic converter. (Not related issues)
Old 11-02-2014, 06:04 PM
The Neens's Avatar
The Neens The Neens is offline
2002 Chevy TrailBlazer LS
I just finished cleaning the throttle body, haven't driven it yet...What's your exhaust issue?
EFI Live by SE Performance, Derale trans cooler by me, Kooks '06-'09 header
Old 11-02-2014, 06:09 PM
Black 4.2L I6 2WD
Not sure yet diagnosing it now. Symptoms Rough idle and rumbling sputtering feel through acceleration. When Im braking (stopped) as I slowly release it starts to jerk forward. This just started this morning any info helps. Will update with findings. Thank you
Old 11-03-2014, 06:16 AM
Black 4.2L I6 2WD
Well I finally found the problem I pulled all the coils and cleaned them up and as I was cleaning up the cylinder head I spotted a small ship off the 3rd dry well lip and sure enough it has white smoke remenents all over the right side of the head and engine bay. Not sure of what to do...any thing helps. If I could figure out how to post a pic I would.
Similar Threads
OEM Trailblazer, Envoy Electronic Visco Fan Clutches EuroPartsAmeric Basic Vendor GroupBuys 26 01-14-2012 02:54 AM
Idle RPM surges and the motor stall when A/C is turned on na svt OEM Issues 6 07-07-2008 12:32 PM
03 Envoy SLT A/C help asap rolin51 OEM Issues 6 08-13-2007 01:45 PM
What would you get? ImARockStar TrailBlazer / Envoy Chat 9 03-03-2007 10:21 AM
Is the A/C off when Heat is turned on? mrbflat OEM Issues 8 02-17-2007 10:16 PM
