Oil Pressure Gauge - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain
02-09 Vortec 4.2L I-6 Engine and Drivetrain Q&A forum for engine and drivetrain repairs/modifications/tuning.
Old 12-18-2005, 08:38 PM
Dirtkicker Dirtkicker is offline
2009 GMC Envoy SLE
Steel Gray Metallic 5.3L V8 2WD
Oil Pressure Gauge
Help....my oil pressure gauge is going bonkers. When I turn off the TB it stays at 75-80, then once started it goes way past 80. The oil was just changed 2 days ago and is fine now. It was acting up before the oil change. Once I remove the fuse to the instrument panel and start it and then put the fuse back in, the oil gauge goes back to 0 while off and to 40 once started. Of course that only lasts for 1-2 starts then it goes bonkers again. Is there an easy fix for this? If so what is it? Thanks.
Quick reply to this message
Old 12-18-2005, 08:52 PM
dpm6836 dpm6836 is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 4X4
Sounds like it is just the gauge since it shows pressure when the engine is off. However, I'm not a mechanic. Personally, I would have a mechanic check the engine oil pressure just to be sure, when replacing the gauge. They can do that by attaching a gauge to the oil pressure sending unit.
Looks like your military. Don't get taken advantage of. Have it fixed at home or from a trustworthy mechanic.
Old 12-19-2005, 05:12 PM
2009 GMC Envoy SLE
I will probably take it to the dealer, but I was just wondering if it was something I could do at home instead. I thought it might be a little sensor that needs replacing instead of the whole gauge. I'll have to let you all know for future reference.
I am in the United States Air Force, the dealer here is pretty decent most of the time. Thanks for your comments.
Old 12-20-2005, 02:58 PM
my-tb's Avatar
my-tb my-tb is offline
2007 Chevy TrailBlazer LS
Bordeaux Red Metallic 4.2L I6 2WD
Here is my question. I just had my cluster replaced for the tach doing its clicking thing and since I have had it back the oil pressure is WAY up it was about 40 at idle now at about 60. So what is the pressure suppose to be on these things? Its about 75 when at full throttle where as before it would only get to about 55. Any ideas guys?
04 LS 2wd, 3.73, G80, 20% tints, K&N, Running Boards
(sold)
07 LS 2wd, 3.42, moonroof, bone stock...for now
Old 12-20-2005, 10:13 PM
2009 GMC Envoy SLE
Mine always idled around 40 and would move up to around 52-53 while driving, that is until recently when it's messed up on me. From the other posts on other threads I read others have said about the same thing. You can always do a search on the main page for oil pressure and there's a post about it.
Old 12-21-2005, 11:55 AM
Black 4.2L I6 4X4
I don't know if there is any specific number because the pressure will vary due to oil weight, type and amount in the engine. I believe the gauge in the TB are there for a general purpose and not an exact reading. If your reading high I would be concerned though, you don't want too much pressure because you might blow gaskets.
Hopefully, a GM Tech with add to this thread.
Old 12-21-2005, 11:57 AM
Black 4.2L I6 4X4
yes, pressure will go up with higher rpms.
Old 12-21-2005, 12:39 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
Summit White 4.2L I6 2WD
From the GM technical overview description of the 4.2 I6
"As oil enters the pump, the eccentric design compresses the oil, then releases the oil at a regulated max pressure of 65 psi at 2,500 rpm, circulating 11
gallons per minute."
It definitely should not be reading 75 psi. Sounds to me like maybe the instrument cluster needs reprogramming, like it is not responding properly to the oil pressure signal.
Old 12-23-2005, 11:18 AM
gabe gabe is offline
New Member
my oil gauge reads about 42 lbs. @ idle then it barely moves. it mite go up one or two lines at freeway speeds. the one in my dodge works like an oil gauge should work. lots of movement between idle and freeway speeds. i cann't believe i have 42 lbs. of oil pressure at idle.
2005 envoy denali other car is a 2003 ram diesel with a few goodies added.
Old 12-23-2005, 02:06 PM
my-tb's Avatar
Thanks tblazed! Its good t o know that you can get answers here. But you would have thought they would have made sure the thing was working right when they put in the new cluser. All I am asking for is some good sense with the techs thats all. Next question? Will that reprogram fix the gas gauge that reads about 5 gallons to low? and my low gas light will not come on for nothing. The gauge was past E and still would not go on. Thanks again all.
(sold)
You may not post new threads
You may not post replies
Similar Threads
4.2L Oil Pressure Gauge Isn't! robdunn1 02-09 Vortec 4.2L I-6 Engine and Drivetrain 14 02-19-2016 11:44 AM
WI Dealer giving me the BS on OCI? Knightslugger General 48 10-10-2009 11:12 AM
Oil Pressure Gauge hustlinuall2 Interior 9 02-04-2008 10:14 AM
Whats your Oil Pressure gauge Say.. njezrider Interior 15 11-30-2007 06:00 PM
05 TB DOD status? muddy tires 02-09 Vortec 4.2L I-6 Engine and Drivetrain 19 07-28-2006 10:00 PM
