04 Will NOT Start - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 10-22-2007, 11:26 PM
bradt bradt is offline
2004 Chevy TrailBlazer LS
04 Will NOT Start
Hi all, I am new to the site and have a specific Problem. When I put the key into the ignition and turn the key my gauges and all go Hay wire. Turn the key and nothing !
I can not even put it in gear, with the key in the normal position. I step on the brake and the button on the shifter will not go in.
I checked the battery there is 13.2 volts and all the lights, radio etc.. work. I tried boosting it and it was getting 13.8 volts for about 20 minutes. SAME Thing as before, gauges that go haywire.
Is this a potential common problem ?
Is this a possible ignition problem ?
Any suggestions on where to look would be appreciated.
Thanks
BRad
Old 10-23-2007, 01:10 AM
ssmedt's Avatar
ssmedt ssmedt is offline
2004 Buick Rainier
Cashmere Metallic 4.2L I6 2WD
sounds like the ignition switch. i had the same problem with the same symptoms on a 97 blazer; turn the key and light light up but no crank and can't put it into drive, nothing except dash lights and my problem was the ignition switch.
Old 10-23-2007, 05:13 AM
-crash- -crash- is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 4X4
just for the asking did you pull your positive post off and inspect ? sometimes those darn things snap ! and look as though they are fine. other than that with also thinking the ignition switch for sure as they are a very common problem with the trailblazers. good luck
Old 10-23-2007, 05:38 PM
hingarfi hingarfi is offline
2002 Chevy TrailBlazer LT EXT
Carbon Metallic 4.2L I6 2WD
Ignition Switch
Hey guys. I have read enough to suspect my ignition switch. Is this a DIY project? If so, is it a major skill project? How about the required PN for 2002 TB EXT.
Hingarfi -- Texas
2002 TrailBlazer EXT I6 3.42
Old 10-23-2007, 08:28 PM
Thanks for the answers, I did look at the battery posts as I too have heard of that problem.
I actually switched the battery with my Malibou, this did not fix the problem. Same problem and symtoms.
Brad
Old 10-23-2007, 08:38 PM
superman_79065's Avatar
superman_79065 superman_79065 is offline
Senior Member
Black 4.2L I6 4X4
How mechanical are you? I did my switch myself, with a little helpful advice from a GM tech. Advice that I now pass on to you, grasshopper. ...
First things first....is the key stuck in the ignition? If so, directly underneath the key cylinder, in the bottom half of the steering collumn cover, you'll notice a small plastic cover with a slot in it. Remove this cover carefully with a screwdriver or pocketknife and set it somewhere you won't lose it. Inside the hole you've just uncovered is a metal button that when pushed with a pen or small screwdriver will release the key from the cylinder.
Now remove the screws that hold the upper and lower halves of the steering collumn cover together. The cover is also held together with some plastic slots and clips that are molded into the covers themselves, so be careful not to break these off. With the cover removed, you can see the screws that hold the switch to the cylinder. I believe these are torx head screws, but not theft-proof.
Now, the trick is making sure the new switch is in the same position as the old on when you replace them. There is an internal gear in the switch that is slightly exposed and meshes with a gear in the ignition cylinder. If the new switch is in a different position then the switch you took out, this makes for many headaches and much cursing of Gm and electricity in general. According to the GM tech I talked to, the switches are supposed to ship in the "off" position. So, theoretically, an unopened switch from the dealer should be in the "off" position. Making sure you'r key is in the off positon on the switch before removing the old switch should ensure that you don't have any problems being out of position.
Old 10-24-2007, 07:19 PM
TBlazeruss44's Avatar
TBlazeruss44 TBlazeruss44 is offline
Senior Member
I'm not trying to break balls or anything, but should you,as a precaution, disconnect the negative battery terminal first-before starting this type of DIY project?
~Eric~ PCMforless tuned (again) and still loving it!!!
Old 10-24-2007, 07:29 PM
Senior Member
Black 4.2L I6 4X4
Absolutely right....sorry I left that out. Basically, you should disconnect your neg cable before attempting ANY electrical repair on these vehicles....
Remind me to tell you all the story about me shorting out my XM and disabling my TB for a few days sometime....
Guns don't kill people...Chuck Norris kills people.
Old 10-24-2007, 08:08 PM
ThEx CoNvOy x07's Avatar
ThEx CoNvOy x07 ThEx CoNvOy x07 is offline
2004 GMC Envoy SLT
Midnight Black 5.3L V8 AWD
I agree
Old 10-24-2007, 08:14 PM
Good point, When you get all excited to jump in there you forget these simple things
Thanks
Brad
Similar Threads
Hard start first thing DonWs05 OEM Issues 40 01-28-2008 06:35 PM
Remote start shorts BCM mfizzy Audio and Electronics 13 11-28-2007 03:31 PM
remote start - truck shutting off after a few seconds TheWraith Audio and Electronics 21 10-21-2007 10:03 AM
TB won't start... TuBlaz General 22 08-18-2007 10:10 PM
No Start Condition... Dacomputernerd 02-09 Vortec 4.2L I-6 Engine and Drivetrain 8 10-04-2006 09:01 PM
