How to: Replace blower resistor pack replacement WITH PICS! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 10-23-2007, 07:08 PM
K2JJB's Avatar
K2JJB K2JJB is offline
2002 Chevy TrailBlazer LS
Black 4.2L I6 4X4
I had a shot blower resistor pack (no 1,2 or 3 speeds on the blower) so I ordered a replacement unit. It arrived today and I put it in just now. I looked around and did not see a "how to" on it, so maybe this will help some others.
Vehicle 2002 Trailblazer LS - no automatic temp controls
Time spent: about 20 minutes (spent time getting the right stuff from the garage ).
Part: blower motor resistor (I used parts4chevys.com so I used the drill down menu to find it, sorry I do not have the PN handy)
Tools:
7mm socket or nut driver
7/32" socket or nut driver
one long screw driver (flat blade) - optional
flash light - optional
step one: locate the two 7mm screws holding the plastic kick plate under the passenger side dash, remove them, and then carefully remove the plastic cover
step 2: look up under there and you can see the old resistor pack. It has one connector and a pair of wires going from it. Unscrew the two 7/32" screws and it will come down, unclip the wire harness
step 3: open the glovebox and empty it, now release the catch so that it can hang down
step 4: locate the end of the wires that came from the resistor pack, they are plugged into the blower, release the clip and remove them (I used a screw driver to push in on the little clip to release it)
step 5: reverse the process and install the new one
here is the comparison of the two
hope that helps somebody....
From the Roadie: Since everybody looks in this post if they use a search, I'm just going to add the schematic HERE for one-stop shopping
Click image for larger version
2002 Trailblazer LS (~90k miles)
Old 10-23-2007, 09:07 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Nice job, thanks. Maybe one of the mods can move this to the articles section.
Ray
Old 10-23-2007, 10:08 PM
rubberman's Avatar
rubberman rubberman is offline
2004 Chevy TrailBlazer LS EXT
Dark Gray Metallic 4.2L I6 2WD
can yoiu list the part no and price for the part? thanks
2004 TB EXT I6 CAI, PCM4Less PCM, Resonator delete, Kuhmo KL51
Old 10-24-2007, 07:04 AM
johnblahblah's Avatar
johnblahblah johnblahblah is offline
2003 Chevy TrailBlazer LS
Great article Just what I need when my resistor pack comes in.
Thanks!
John
Old 10-24-2007, 07:49 AM
K2JJB's Avatar
Black 4.2L I6 4X4
Where I ordered it from does not show the PN, sorry. I just used their drill down menu until I found
"Mechanical Catalog - 2002 - Chevrolet/Geo - Trailblazer
Hvac, Controls, Blower motor, Resistor, Resistor, s-series, bravada/envoy/trailblazer"
I also did not see a part number on the part itself.
It cost me $38 + s/h. The local dealer here wanted $60 for it, so it was better than that even with the shipping.
Old 10-24-2007, 09:07 AM
duff76's Avatar
duff76 duff76 is offline
2002 GMC Envoy SLE
AcDelco # is 15-81095 if that helps any.
Old 02-12-2008, 02:35 PM
lineman82's Avatar
lineman82 lineman82 is offline
2005 Chevy TrailBlazer LS
thanks
Old 02-13-2008, 07:53 AM
Blazernut's Avatar
Blazernut Blazernut is offline
Western Canada Chapter
2003 TrailBlazer and '09 Kadillak Eskalade __
sExY Dark Gray Metalic 4.2L I6 4X4
Great write up!
part # 89019100 I think mine was about $35. The best part about Parts4Chevys is that they have reasonable shipping rates compared to others.
Under the Resources tab, at the top right of the page, there are a bunch of part numbers listed for various items. We as members can add to this list and keep it current for any and all parts. A great helper for ordering for mods and regular replacement parts
Bill
trailvoy.com
Let's get a Meet going!
Old 03-06-2008, 08:21 PM
OldSVTGuy OldSVTGuy is offline
2004 Chevy TrailBlazer LT
Yep, replaced mine about 3 months ago. Took longer to find it than to actually replace it. The new part was very different looking, as shown above, than the old part. Maybe an upgraded part??
Old 03-07-2008, 08:59 AM
05TBLS 05TBLS is offline
I did this repair last weekend. I lost fan speed #5, and put it off for a while.
This write-up was very helpful, and other than needing to be a contortionist, it wasn't too bad a job.
Tags
how to
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
You may not post new threads
You may not post replies
Similar Threads
AC/Heater Blower Quits then Starts payner1018 General 11 04-27-2012 01:10 PM
Auto Air Blower Fan Intermittent Slugbug OEM Issues 16 04-10-2011 03:40 PM
Blower Motor AndrewB General 3 10-14-2010 09:50 PM
Anyone in Philadelphia Area able to change actual mileage? TrailinAlong517 TrailBlazer / Envoy Chat 10 11-13-2009 06:43 PM
Bad Blower Motor? zoomy General 1 08-05-2006 04:42 PM
