How to: Replace blower resistor pack replacement WITH PICS! - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 05-28-2008, 11:46 PM
Robert1101's Avatar
2003 Chevy TrailBlazer LS
Yes, and you should loose speeds 2, 3, 4 in time. Mine ran backwards, I lost 4 and then 2 but 3 was close behind. Fix it while summer is not quite here.
Robert
Old 05-29-2008, 12:11 PM
rrufast's Avatar
rrufast rrufast is offline
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
Thanks for the quick reply. I'll get around to ordering the new replacement soon enough. At least this looks to be a relatively simple and cheap fix... ;-)
EDIT- Just order from GMPartsDirect.com. Total was $38 and change. They are in NC and I'm in SC, so I should have it in a few days. Learned that GMPD is actually a subsidiary of FLOW Motors, which is out of Winston Salem if I'm not mistaken. Anywho.. hope this solves my problem with no air on fan setting 1.
Southeast Chapter SC Rep The Happiness of Society is the END of Government!
  #23
Old 06-03-2008, 09:00 PM
rrufast's Avatar
Talking
Got the part in today. Took me all of 10 minutes to remove and replace.
Miraculously, fan speed 1 now works..
Thanks again TV...
To the OP.. for the pics also. Being able to get a 'visual' on things really helps me out..
  #24
Old 07-19-2008, 11:00 PM
jl830344 jl830344 is offline
Black 4.2L I6 2WD
I lost my #5 speed, and replaced this resistor today in about half hour. $39 from gmparts direct. Works great now that my TB sat in the sun today at about 92 degrees outside. Cooled quickly...
  #25
Old 07-24-2008, 01:06 PM
pauljohnson pauljohnson is offline
2002 Chevy TrailBlazer LS EXT
Pewter Metallic 4.2L I6 AWD
I used these directions on 7/24/08 and found them to be spot on
[QUOTE=K2JJB;443102]I had a shot blower resistor pack (no 1,2 or 3 speeds on the blower) so I ordered a replacement unit. It arrived today and I put it in just now. I looked around and did not see a "how to" on it, so maybe this will help some others.
Vehicle 2002 Trailblazer LS - no automatic temp controls
Time spent: about 20 minutes (spent time getting the right stuff from the garage ).
Part: blower motor resistor (I used parts4chevys.com so I used the drill down menu to find it, sorry I do not have the PN handy)
Tools:
7mm socket or nut driver
7/32" socket or nut driver
one long screw driver (flat blade) - optional
flash light - optional
step one: locate the two 7mm screws holding the plastic kick plate under the passenger side dash, remove them, and then carefully remove the plastic cover
step 2: look up under there and you can see the old resistor pack. It has one connector and a pair of wires going from it. Unscrew the two 7/32" screws and it will come down, unclip the wire harness
step 3: open the glovebox and empty it, now release the catch so that it can hang down
[I used these directions on 7/24/08 and found them to be spot on. I had lost speeds 1,2, and 5. Part cost $53.94 at dealer
  #26
Old 07-30-2008, 08:56 PM
nearpar nearpar is offline
2003 GMC Envoy SLE
Thank you !
I had to replce the blower motor resistor pack on the 2003 Envoy this was most helpful !
Thank you !
  #27
Old 08-16-2008, 09:36 PM
shocker shocker is offline
2005 GMC Envoy SLE
Imperial Blue Metallic 4.2L I6 2WD
i have change mine on a envoy 2005 but the 4 speed stop working again after 1 week???
anyone know why
  #28
Old 08-17-2008, 08:41 AM
K2JJB's Avatar
K2JJB K2JJB is offline
Black 4.2L I6 4X4
anyone know why
a while back I recall reading on here that someone (maybe it was The Roadie? I just can not remember) on here had issues that when the resistor pack went bad it got the connector that went to it really hot as well. That caused the contacts in there to have issues so that when they put the new one in there the resistance of the contact itself eventually caused the connection to get hot and then open up. They had to replace the resistor pack and the cable that plugs into it to fix it. Might be worthwhile to unplug the harness from the resistor pack and see if it looks discolored/disfigured.
2002 Trailblazer LS (~90k miles)
  #29
Old 08-17-2008, 02:15 PM
reedtchsrv's Avatar
reedtchsrv reedtchsrv is offline
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
I just ordered my resistor pack due to not having 1,2 or 3. Just found this in another forum:
Subject: EI05082 - Loss of Blower Motor Speeds Except for Low Speed or Inoperative (Replace Blower Motor Resistor and Resistor Module Connector) keyword fan #05-01-38-012C - (11/02/2006)
Models: 2004-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe, TrailBlazer, TrailBlazer EXT
2007 Chevrolet Silverado (Classic) Built Prior to September 1, 2006
2004-2006 GMC Envoy, Envoy XL, Sierra, Yukon, Yukon Denali, Yukon XL
2007 GMC Sierra (Classic) Built Prior to September 1, 2006
with HVAC System AC Front, Manual Temp Control (RPO CJ3) or Heater Only (RPO C42)
This bulletin is being revised to clarify the Warranty Information. Please discard Corporate Bulletin Number 05-01-38-012B (Section 01 -- HVAC).
Condition
Some customers may comment that the blower will only work on low speeds or has become inoperative.
Correction
REPLACE THE BLOWER MOTOR RESISTOR AND RESISTOR MODULE CONNECTOR.
Replace the blower motor resistor and module connector using the following procedure:
Remove the blower fuse.
Fullsize Trucks and Utility Vehicles -- Htr A/C & HVAC 1 fuses
Midsize Utility Vehicles -- Blower Fuse 35 located in the Underhood Fuse Block
Lower the hush panel or close-out panel enough to gain access to the resistor module connector.
Disconnect the connector from the resistor module.
Remove the tape from the wiring harness to expose the wiring.
Cut the wires back far enough from the connector to eliminate any melted insulation on the wire.
Tip
Use the old connector as a map for splicing the wires for the new connector. Be sure to use the correct crimping tool from the terminal repair kit J 38125. Use only Duraseal splice sleeves. Other splice sleeves may not protect the splice from moisture or provide a good electrical connection.
Install the new connector. Use the yellow splice sleeves provided with the connector.
Install new blower motor resistor.
Reinstall the fuse or connector block. Test the blower motor to make sure all speeds are functional.
Reinstall the hush panel/close-out panel.
Parts Information
Important: To determine which resistor to use for Fullsize Truck/Utility vehicles, search the parts catalog using the vehicle's VIN.
Part Number
Description
Qty
15862656
Connector - Resistor Blower Motor (includes splice sleeves)
1
89019088
Resistor -- Blower Motor (Fullsize Truck/Utility)
1
89019089
1
89019100
Resistor -- HVAC & A/C (midsize utility vehicles)
1
  #30
Old 08-28-2008, 08:17 PM
JRF001 JRF001 is offline
2002 GMC Envoy SLE
Light Pewter Metallic 6.0L LS2 V8 4X4
Resistor Pack Replacement
Thanks! I just fixed my 2002 GMC Envoy August 28 2008. Your information save me 150.00 dollars. That may not included the part from the Dealer. The part cost me 25.00. The directions worked great.
Tags
how to
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
Similar Threads
Bad Blower Motor? zoomy General 5 11-08-2014 03:25 PM
Auto Air Blower Fan Intermittent Slugbug OEM Issues 18 01-30-2014 05:16 PM
AC/Heater Blower Quits then Starts payner1018 General 11 04-27-2012 01:10 PM
Blower Motor AndrewB General 3 10-14-2010 09:50 PM
Anyone in Philadelphia Area able to change actual mileage? TrailinAlong517 TrailBlazer / Envoy Chat 10 11-13-2009 06:43 PM
