How to: Replace blower resistor pack replacement WITH PICS! - Page 67 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 05-05-2013, 02:57 AM
Pipper44 Pipper44 is offline
2004 GMC Envoy SLT
Blower motor wont turn off or chnge speeds
Hey all,
The blower motor won't shut off on my '04 Envoy SLT.
I have to pull the fuse, because it will continue to run after vehicle is shut off.
Is it the resistor as well? Or is it something more?
Thanks
Old 06-01-2013, 09:47 PM
CZSteve CZSteve is offline
2004 GMC Envoy SLT XUV
Bordeaux Red Metallic 5.3L V8 2WD
Joining the blower resister club - auto digital ?
Looks like our blower resister pack is going out on our 2004 XUV w/ the digital auto control.
Fan quit blowing completely then while my wife cycled it on and off it started blowing but will not ramp up in fan speed pass the medium speed.
Is the following ACDelco 15-80567 correct for a 2004 Envoy XUV w/ digital auto?
http://www.amazon.com/ACDelco-15-805...ule+2004+envoy
Another Question: I've never cared for the automatic HVAC control; seems like it will not 'blend' the temperature; either blows cold or hot, never a blend - very frustrating and has always been this way.
Is this normal for the digital auto system?
If not, anything else to look at?
If this is normal, is possible to 'easily' swap the control a manual system?
Thanks,
Steve
2004 GMC Envoy XUV
2WD
  #663
Old 06-03-2013, 11:22 AM
Krissrock Krissrock is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
sweet, gonna attempting this next weekend. I lost 1 & 2 yesterday and can only have the air blasting on 3 & 4 (5 has never worked). Or, I gotta keep the car moving to get AC...
thanks
  #664
Old 06-05-2013, 06:39 AM
Robcerv8 Robcerv8 is offline
2004 Chevy TrailBlazer LT EXT
Silver Mist Metallic 4.2L I6 2WD
2004 Trailblazer EXT Rear blower works sometimes
Took it to the dealership and they wanted $850 to replace the auxiliary blower resistor. Does anybody know where this is located? I took apart the rear passenger side where the rear blower is located and I could not find a resistor. I replaced the front resistor under the glove box last year.
Please help we are driving to Florida from Texas in 2 days.
  #665
Old 08-25-2013, 05:02 PM
rsfurlong's Avatar
rsfurlong rsfurlong is offline
2004 Chevy TrailBlazer LS
Graphite Metallic 4.2L I6 2WD
Once again, the TrailVoy forum has saved me hundreds of dollars.
I replaced the resistor 2 years ago when I lost speeds 1-3 on my a/c.
7 days ago, the a/c quit blowing on all speeds. It would work for a few seconds and quit for a day or two. Then work for a few seconds and quit again.
After removing the blower motor, I found two halves of a pecan hull, several dead leaves and some chewed up insulation.
I also removed the vent tube from the motor housing and used compressed air to blow out all the gunk, cleaned the armature with a pencil eraser and adjusted the brushes best I could.
Reinstalled the blower motor and started my TB.
To my surprise, the blower worked on all 5 speeds.
Took a total of 30 minutes including the cleaning and reinstall.
Thanks again to ALL contributors to this forum.
We found your stolen Prius, it was voting for Obama.
  #666
Old 09-10-2013, 02:12 PM
GA Jason's Avatar
GA Jason GA Jason is offline
2008 Chevy TrailBlazer LT
Dk Brahma Jewel Metallic 4.2L I6 2WD
So my fan is now only working on a very low speed (I have the Auto Temp Control) when I crank up the fan speed on the manual control for the fan it stays at that same low speed. I ordered a new resistor pack based on what I have read here but did not see any mention of what wires will need to be spliced from the old harness to the new harness. I see from my research that with the ATC I will need to splice in some wires, anyone know which ones???
PS, Ive been looking for a while and could find no mention of the wires to splice so if I messed it and it was right in front of me I apologize for wasting time.
Late to add: I ordered ACDelco 15-81773 which was described as a direct fit application.
  #667
Old 09-13-2013, 02:16 PM
JOHNER's Avatar
JOHNER JOHNER is offline
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Thumbs up
Great info, mine lost #1,2,5 going to replace this week.
  #668
Old 12-05-2013, 11:23 PM
Lakeliving Lakeliving is offline
2002 GMC Envoy SLT
Pewter Metallic 4.2L I6 AWD
New owner here and curious on the current replacement and splicing. GA Jason did you get this figured out?
Thanks
  #669
Old 12-08-2013, 09:51 PM
2002 GMC Envoy SLT
Turned out the blower motor was shot. Picked up for $15 at local auto salvage and all is good! Also bought an extra module for $10 out of the car as well.
  #670
Old 12-14-2013, 09:24 PM
metalmike92 metalmike92 is offline
I just replaced the resistor, and its still not working. the old resistor was corroded and definitely bad. Any ideas what would be causing the problem?
Tags
how to
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
Similar Threads
Bad Blower Motor? zoomy General 5 11-08-2014 03:25 PM
Auto Air Blower Fan Intermittent Slugbug OEM Issues 18 01-30-2014 05:16 PM
AC/Heater Blower Quits then Starts payner1018 General 11 04-27-2012 01:10 PM
Blower Motor AndrewB General 3 10-14-2010 09:50 PM
Anyone in Philadelphia Area able to change actual mileage? TrailinAlong517 TrailBlazer / Envoy Chat 10 11-13-2009 06:43 PM
