U-joints Clunking - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > OEM Issues
Old 10-24-2007, 11:15 AM
Spong's Avatar
Spong Spong is offline
TrailVoy Guru
2006 Chevy TrailBlazer LT
Zaino Shined Red Jewel 5.3L V8 4X4
U-joints Clunking
Anyone had to have the U-joints replaced? My TB has 14,128 miles on it and the U-joints have been clunking for some time but I've noticed they are really getting bad.
I only notice it when I'm driving slow with not much load on them (like leaving my driveway and heading easy down the street). The biggest clunk seems to be when the tranny goes from 2nd to 3rd.
I've heard this on full size trucks before but not TB's. Just wondered if anyone else has?
Old 10-24-2007, 11:28 AM
superman_79065's Avatar
superman_79065 superman_79065 is offline
Senior Member
2002 Chevy TrailBlazer LT
Black 4.2L I6 4X4
I've got almost 125k om my TB and never had a problem. Nor did I ever see a TB come in for u-joints when I worked at the dealership. I guess it's possible though. Are you sure it's u-joints? Have you inspected them?
Guns don't kill people...Chuck Norris kills people.
Old 10-24-2007, 11:33 AM
Spong's Avatar
TrailVoy Guru
I haven't gotten under the truck and looked at them. The sound is just like U-joints. It's a loud clunk and it sounds like it comes from the rear. It doesn't do it under acceleration load, only when under very light load when the tranny upshifts.
What's the best way to check them? Grab the driveshaft and try to turn it back and fourth?
Old 10-24-2007, 11:45 AM
Senior Member
Black 4.2L I6 4X4
YEP....get under there with a flashlight and twist and turmn the driveshaft looking for slack at the u-joint. You'r rear-end might clunk a little while doing this, but focus on the joints. There shouldn't be any give at the joint, nor should there be fluid or grease around the joint. If you're jacking the truck up to do this, be sure you have plenty of medical and life insurance.
Old 10-24-2007, 11:48 AM
PROSPHOTO's Avatar
PROSPHOTO PROSPHOTO is offline
Superior Blue Metallic 4.2L I6 4X4
I hear this too, but haven't inspected it yet...maybee it's an '06 issue
I doubt you'll be able to check/feel the U-joints by hand...The best way to check it is to get under the truck and watch the driveshaft while someone else is inside shifting (w/the parking brake on) from D to R
If you can't tell visually, but hear the "clunk" while checking, try to isolate the location that the clunk is coming from (driveshaft, T-case, Tranny, rear)
-Mike
AKA PROVY
Rock On!
Old 10-24-2007, 12:04 PM
Senior Member
Black 4.2L I6 4X4
Again, perform this procedure with plenty of insurance.....or make your friend get under the truck and you shift....hahaha
Old 10-24-2007, 12:13 PM
Spong's Avatar
TrailVoy Guru
What if I put the rear end on jack stands and then put the truck in gear, run it up to 100 and set the cruise? Then reach inside, turn the switch to 4 Hi and then stand back.
Old 10-24-2007, 12:16 PM
Senior Member
Black 4.2L I6 4X4
That sounds like an excellent plan. My charge for rebuilding garage walls is quite cheap.
Seriously though, everyone PLEASE be careful when jacking up your vehicles and working on them! The tire changing jack under your seat is NOT sufficient for these operations. Spend the 40 bucks and get a decent floor jack, some jack stands, and some wheel scotches.
Old 10-24-2007, 12:20 PM
Spong's Avatar
TrailVoy Guru
My neighbors think I'm crazy.
Old 10-24-2007, 12:22 PM
Senior Member
Black 4.2L I6 4X4
one man's crazy is another man's OCD
is this how you commonly wash your undercarriage? is this like a weekly ritual? Because if so, you ARE crazy.....hahaha
Similar Threads
Replacing lower ball joints on 2003 TB TechBill Suspension 9 12-16-2007 12:11 PM
Changed my ball joints and tie rods 02envoy05r1 Suspension 4 12-03-2007 10:44 PM
clunking sound while in AWD skibumbs2 4x4 Drivetrain 6 11-23-2007 09:19 PM
Clunking Noise from Rear after BDS lift. Karo Off-Road 11 09-27-2007 08:15 AM
Clunking Noise from Rear after BDS lift. clint_col Suspension 7 09-14-2007 01:58 PM
