Rear end Gear oil 75w-90 confusion - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-08-2007, 02:58 PM
rbarrios's Avatar
rbarrios rbarrios is offline
TrailVoy Guru
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
So im going to change the rear end gear oil.
So in the other thread regarding the draining of the rear end- the question came up- whats a suitable replacement. The manual calls for
SAE 75W-90 Synthetic Axle lube GM part # 78261 or meeting GM spec 9986115.
Well naturally, i go around looking to see who meets that spec. Seems there arent too many. Not even Mobil 1. I emailed Mobil 1 this morning. No reply yet. But I found a thread at another forum where this same issue came up.
One of the posters seems to be an engineer (im guessing GM????).
But its an interesting post- that confused them- and confuses me too as to what is the correct oil to use (aftermarket). I know that if I used something other than whats called for- id be having constant thoughts for the rest of my life- DID I USE THE WRONG FLUID?????.
At this point im very tempted to simply go to dealer and get the grape scented stuff that meets the GM spec- though Id pay quite a bit more- at least id have peace of mind regarding whether I have or do not have friction modifiers etc. etc...... I thought it would be as simple as going to auto parts and getting a bottle of gear oil.... but not that simple....
(for my 07 Impala- manual called for engine oil meeting a certain spec- no bottles listed this spec- thought website showed their spec data sheet did meet this GM spec- so i feel comy with that brand)... but I dont feel comfortable at this point with any of the gear oils- as none show them meeting that spec....
heres the very interesting thread.
http://www.bobistheoilguy.com/forums...782900&fpart=1
Old 11-08-2007, 03:11 PM
rbarrios's Avatar
TrailVoy Guru
got reply from Mobil1.... seems ill just stick to the GM stuff...
"Mobil does not have a product that will meet your requirement, please
procure from your local dealer."
Old 11-08-2007, 03:22 PM
BryTblzr's Avatar
BryTblzr BryTblzr is offline
2008 GMC Envoy SLT
From the Amsoil data sheet
AMSOIL Severe Gear® Synthetic Extreme Pressure (EP)
Lubricants 75W-90 (SVG)
“Recommended for use in differentials, manual
transmissions and other gear applications requiring any
of the following specifications: API GL-5, MT-1,
MIL-PRF-2105E, Dana SHAES 234 (Formerly Eaton
PS-037), Mack GO-J, or the differential (hypoid) gear oil
specifications from all domestic and foreign manufacturers
such as GM, Ford and Daimler Chrysler. Can also be used
in axles where an API GL-4 lubricant is recommended.”
If you really want an eye opener, get the Amsoil white paper on Automotive Gear Lubes, catalog #G2457. The testing was done in accordance with ASTM procedures, SAE J306 requirements & Federal Test Method Standards.
Old 11-08-2007, 03:57 PM
tblazed's Avatar
tblazed tblazed is offline
Basic Vendor- DRL Killer
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
I couldn't be happier with the Royal Purple Max Gear oil I put in mine several years ago. Stopped a little bit of pinion shaft seal seepage. Locker works perfectly. Total cost : about $20.
Old 11-08-2007, 04:05 PM
rbarrios's Avatar
TrailVoy Guru
interesting white paper....
so in the test- AMSOIL was the best choice
Old 11-08-2007, 04:27 PM
rbarrios's Avatar
TrailVoy Guru
I just ordered my 2 qt of Amsoil. Wonder when theyll get here- I doubt ill do the swap this weekend. Thanks for the white paper.
Old 11-08-2007, 07:24 PM
BryTblzr's Avatar
2008 GMC Envoy SLT
I'm changing mine too
Your welcome!
I hope that I can get at it before too long and change the front and rear grease on my Envoy, that has just under 1,000 miles.
Old 11-08-2007, 10:30 PM
pvgoheelsunc1 pvgoheelsunc1 is offline
2003 Chevy TrailBlazer LT
Well here is your sign. BUT this is NOT a GM service bulletin ..... Amsoil gear oil. I'm looking for other brands also. If I find will post it...
http://www.performanceoiltechnology....rear_axles.pdf
Old 11-09-2007, 12:56 AM
rbarrios's Avatar
TrailVoy Guru
another excellent link.
That one specifically says it will meet the requirement....
Old 11-09-2007, 09:40 AM
Click on the link... https://www.amsoil.com/storefront/svg.aspx .... This is the gear oil in the TSB above. On the TSB. GM tells that they fill at the factory in G80/LS axle's 2 separate fills, a gear oil then an additive. When GM dealers do a replacement of gear oil, they use the GM part # for refill. That has the additive included for LS axles. GM owners manuals say to use GM part # OR the equivalent #9986115. The reason owners manuals, and Motor Information Systems both print the statement, “Do not add friction Modifier” is that GM specification #9986115, part #12378557 (USA) or #88901362 (Canada) have the limited slip friction characteristics already in the formula.
Now I'm not a lawyer and I don't have a Masters degree in the English language in order to play with words. But, the equivalent #9986115 for GM and the Amsoil 75W-90 (SVG), is a synthetic GL-5, MT-1 oil. Amsoil says on the web site """"Recommended for use in differentials, manual transmissions and other gear applications requiring any of the following specifications: API GL-5, MT-1, MIL-PRF-2105E, Dana SHAES 234 (Formerly Eaton PS-037), Mack GO-J, or the differential (hypoid) gear oil specifications from all domestic and foreign manufacturers such as GM, Ford and Daimler Chrysler""". IMHO and that's all it is, GM's #9986115 is plain old GL-5, MT-1 Synthetic oil that can be purchased at AUTO ZONE, NAPA or any other parts house that sells MB1, Castrol, Valvoline, RP, Redline. Look for the GL-5, MT-1 on the bottle for LS axles...................
Similar Threads
Rear end rattle and squeak Swearingsailor6 OEM Issues 5 12-13-2013 05:29 PM
Rear wiper problem ninesevens10 General 11 09-23-2013 01:55 PM
gear oil leak Silver Mule OEM Issues 10 09-19-2008 09:21 AM
05 TB DOD status? muddy tires 02-09 Vortec 4.2L I-6 Engine and Drivetrain 19 07-28-2006 11:00 PM
Ordered My TB SS SS owner TrailBlazer SS Chat 39 10-04-2005 11:34 PM
